1967 Black Plastic Inner-Wheel wells
Old Aug 9, 2015 | 12:34 PM
stonecad's Avatar
I'm starting to clean these up and there are 1inch to to 2" long 1/4" wide wear holes on the top towards the inside (top of tire)
I could really use some advice on how to properly repair these. I will need to repair a few mounting hole spots that have torn as well. All in all the mounting locations are in very good shape. I will also need to get some of the fabric/tar paper skirts if anyone has a good lead on them as well.
Thanks for your time.
Old Aug 9, 2015 | 12:45 PM
Mikes442's Avatar
You can take them to an ATV shop that does plastic welding, BUT let them show you their work first. Plastic welding is an ART FORM if done right or it can look like some bird crapped.
Old Aug 9, 2015 | 01:27 PM
Run to Rund's Avatar
The holes will be covered when the inner fenders are on the car. You could use black RTV if you feel you need to fill the holes.
Old Aug 10, 2015 | 08:13 AM
lemoldsnut's Avatar
Another good fix for areas not seen so much is bumper fix that 3m makes I think it is called structural plastic adhesive. I got it at Napa not cheap but very good fix.
Old Aug 10, 2015 | 08:46 AM
Also, the glue used for plastic gas tanks should work.
Old Aug 10, 2015 | 05:52 PM
I use one of these for plastic bumper and other repairs. Works pretty good.
Plastic Welding Kit 80 Watt Iron: Power Soldering Equipment: Amazon.com: Industrial & Scientific Plastic Welding Kit 80 Watt Iron: Power Soldering Equipment: Amazon.com: Industrial & Scientific
texasred
Body work
Mar 1, 2025 10:06 PM
tru-blue 442
Dec 18, 2013 11:36 AM
1k442
Nov 27, 2013 11:46 AM
1k442
Nov 15, 2013 07:00 AM
Gary's 2 442-S
Body work
Jan 21, 2012 06:52 PM
