1966 f/85 rear Dash & parking lights
Old May 28, 2011 | 10:47 AM
cintr113's Avatar
Hi Im having and issue with my dash & rear night lights... they dont turn on. When i turn on the switch for the headlights the front light turns on but the dash & rear dont turn on for some reason.. I checked all the fuses and they are all ok.. Now whats also wierd is that when you open the door the dome light turns on butwhen i close the door and try to turn the dome light with the switch it doesnt... im wondering if my actual switch is bad or is there something else i shoulf check??
Old May 28, 2011 | 10:54 AM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Sounds like headlight switch. You can still get them at Napa for $25 I think it was, we had to replace the one in the '65 a few months ago.
Old May 28, 2011 | 10:57 AM
cintr113's Avatar
Could it have to do with the neutral switch on the column by any chance..
Old May 28, 2011 | 11:00 AM
GAOldsman's Avatar
"Car"mudgeon
Try this link 12 a, 12 b & 12 c all pertain to what you're looking at. I think it could be a fuse or your switch. If you have a voltmeter check for power on both sides of the fuses on tail, instrument and panel with engine running and lights on. If any of these is not getting power on both sides then it is a ground or the switch.
http://wildaboutcarsonline.com/cgi-b...aldisplayed=16
Scot
Old May 28, 2011 | 12:40 PM
rocketraider's Avatar
Oldsdruid
Dash and park/tail lights feed off the h/l switch thru fuses. Check the fuse block and see if one for INST LPS or TAIL is blown. Not just visual- use a test light across each clip and make sure the fuse is good.
Neutral start switch does not affect lighting.
Old May 28, 2011 | 06:17 PM
cintr113's Avatar
Ok so I bought a new switch and now I have dome light. I check the fuses and they are all ok but I tested the fuse for the rear lights and there is no current going to that fuse for some reason and the fuse is good. Cause I took it out and tested. Now my question is why is there no current to that one fuse ??? Help
QUOTE=rocketraider;285747]Dash and park/tail lights feed off the h/l switch thru fuses. Check the fuse block and see if one for INST LPS or TAIL is blown. Not just visual- use a test light across each clip and make sure the fuse is good.
Neutral start switch does not affect lighting.[/QUOTE]
Old May 29, 2011 | 12:48 PM
cintr113's Avatar
fuse is good .there is no current in the fuse box to go for the rear lights... but i do have brake and signal... this is confusing can some help...
Old May 29, 2011 | 01:00 PM
cintr113's Avatar
Thank You All
Just wanted to say thank you to all that tried to help... By the way the fuse socket was dirting and was not making contact... incredible...
Old May 29, 2011 | 07:04 PM
Oldsdruid
Not as incredible as you might think. The stuff IS 45 years old. Nothing a little scotchbrite or fiberglass eraser won't help.
scooter123
Sep 28, 2013 07:32 PM
oldstuff
Sep 13, 2011 08:03 AM
Southern_Hospitality
Aug 19, 2011 09:52 AM
Sid
Sep 10, 2010 02:33 AM
