1965 Dynamic Air Filter ???
Old Feb 24, 2013 | 08:56 AM
ROCKET JO's Avatar
I am thinking about buying a 1965 Oldsmobile Dynamic 88 it has the 425 2 barrel engine 310 hp. I was wondering if it has the correct air filter it uses a A124C filter and the part number on the air cleaner assembly is 6420958 is this the oringinal air cleaner assembly?? its painted black , I thought it was supposed to be red , also what color should the block be ??does anyone have a picture of one ? thanks Joe
Old Feb 24, 2013 | 12:40 PM
jaunty75's Avatar
Does the side of the air cleaner look similar to this?
The above is from a '67 425.
Black is the correct air cleaner color, I believe, for the low-compression version of the 425. At least, for 1967, a black air cleaner on a 425 would have been correct in some situations. Red was the correct air cleaner color for high-compression versions of the 425. I'm not sure of the situation for 1965. Others will likely know.
Old Feb 24, 2013 | 02:42 PM
ROCKET JO's Avatar
Yes , this the same assembly , but the part number is 6420958 maybe someone has a parts book to confirm the number ,thanks
BeenThere
May 31, 2015 06:14 AM
bjtstarfire
Jan 19, 2008 03:55 AM
