1965 cutlass emergency brake lite
can someone tell me if a red dot light 2 1/4 inches away on rt side of wiper switch was a factory option . bezel is chrome with the word brake on top thanks mike
I'm not '65 expert, so I can't say whether it was an option, or something else, but some cars definitely have it, while others do not, so it appears as though it is consistent with the original appearance of the car.
Well, to be pedantic, rear drum parking brakes WILL work as emergency brakes. Rear disc "inner drum" parking brakes will simply smoke themselves since they're stupid. But, you are, when you hammer that parking brake, engaging the actual rear brakes of the car, albeit not at the pressure the hydraulics would do it. I have gotten an A body home from a car show by downshifting and the parking brake. It was not hard, most annoying thing was making a whole lot of noise through the Ravens putting it down into first each time I stopped.
I guess the idea, pre-dual cylinder, was you found out you had no brakes via more obvious things than a light?
