1964 olds dynamic 88
Your car has a 5 x 5" wheel bolt circle. You need wheels with near zero offset. Something in the 7" width would be best, depending on tire size. Fitment will depend on the tire size you select. The original tires (8.00x14) were about 28.25" in diameter. 245/55-18s would be about 0.3" taller and would fill the fenderwells nicely. BFGoodrich sells that size in their Radial T/A Spec line. 235/55-18 would be almost exactly the same diameter as the original tires. BFG also sells those in their Advantage T/A line.
You didn't tell us your original tire size or even your year and model, so all I can tell you is that the 215/65-15 is only 26 inches in diameter, which is small compared to the original tires put on most 1960s Oldsmobiles from the factory.
sorry guys. 1964 olds 88 4 door. current tires are 225 65 14...has new shocks and springs are @ 8 years old and I will be giving up the 14inch rims including spare. BTW contact me by PM.
Thanks guys
Thanks guys
225/65-14 tires are about 25.5" in diameter. The original 8.00-14 tires were just over 27.5" in diameter. That results in just about exactly a one inch difference in ride height.
MWS88Dynamic
January 16th, 2007 12:40 PM
