1964 442 question
Old Mar 24, 2014 | 05:07 AM
66luvr's Avatar
1964 442 question
I imagine this seller is just blowing smoke as sellers often do, but thought I would ask to be sure. He says in the ad that it has factory adjustable rear upper control arms. Is that true?
http://www.ebay.com/itm/Oldsmobile-4...US_Cars_Trucks
Thanks,
Old Mar 24, 2014 | 05:18 AM
sixtyfour's Avatar
Thanks,
I bought my 1964 442 new, The upper/lower control arms aren't on mine. and the bottom ones had a plate welded across the u-channel (for lack of better description) on the bottom. I have had Olds guys tell me that was only on the 442.
Old Mar 24, 2014 | 06:30 AM
66luvr's Avatar
WOW, you bought it new! That's great. No better way to figure out the seller is full of bull.
Thanks, I always like learning,
Old Mar 24, 2014 | 06:38 AM
kjr442's Avatar
Kjr442
I can't say for the 64's, but the 65's had the adjustable upper control arms on the rear, but only the 442. The lower boxed control arms, and sway bar were also a part of the 442 package. My guess is that the add is correct.
Old Mar 24, 2014 | 06:44 AM
Kevin45's Avatar
I don't know about the control arms, but why would a person go to that lever of detail on a car, and then not do anything to the inside of the doors? Look at the pic with the passenger door open, then look up and down the door seal at all the rust. Pretty sad to go to that level of restoration and just let the doors go.
Old Mar 24, 2014 | 06:45 AM
stan 65 cutlass's Avatar
they had four holes, either up or down to attach the upper control arms, 442 only
Old Mar 24, 2014 | 08:12 AM
Mikes442's Avatar
There should be a rear sway bar, and I don't see holes in the lower control arms either. The 442 emblems are repops.
My 2 cents.
Mike
Old Mar 24, 2014 | 08:13 AM
66luvr's Avatar
Good stuff Stan, live and learn. Hopefully some day I may see one, or maybe a picture.
Thanks,
Old Mar 24, 2014 | 08:20 AM
F-85 4-4-2's Avatar
Control arms aside, nice car, and nice colors! Although my '66 was red from the factory, I get sick of seeing so many red cars. Looks like it was originally Fern Mist with a Provincial White painted top, J-C.
And it's in Missoula, too.
"I guess it all blew up in Missoula
There just was no other way
After months of goin crazy, there was nothin left to say
But when the dust had finally settled
And the air had quickly cleared
Whoa, things were better off than I had feared"
Old Mar 24, 2014 | 08:34 AM
oldolds88's Avatar
not 442 only,i have a 65 cutlass post coupe parts car that has the extra holes and rear sway bar.
Old Mar 24, 2014 | 08:41 AM
oldstata's Avatar
Justin
On 65 if you had a manual trans it had the 442 frame with the extra holes to adjust control arms for witch rear end you had not sure if it was a 64 thing or not I would visit bro442 web sight to double check on the 64
Old Mar 24, 2014 | 09:46 AM
Octania's Avatar
Yeah, a fine point, "extra holes" and "adjustable control arms" are kind of confusing. What most folks think of an an adjustable CA would be one where its LENGTH is adjustable, not its mounting points.
A better term for that might be "442-type selectable C.A. mounting holes in the frame."
Because the CA itself... is NOT adjustable.
Old Mar 24, 2014 | 09:52 AM
66-3X2 442's Avatar
The reason for the extra set of holes is to adjust the pinion angle. In the 66 PIM(assembly manual) it shows were they go for the 442 models.
Old Mar 24, 2014 | 01:46 PM
oldolds88's Avatar
this car also was a 3 speed on the coluum
Old Mar 24, 2014 | 02:03 PM
TK-65's Avatar
There was an adjustable upper arm used on Chevelles in 1964.
Old Mar 24, 2014 | 04:03 PM
TK-65's Avatar
Most of that is the door panel. Inside the edge of the panel is a metal band that has the studs that snap into the door to hold it on. The vinyl is wore away and you are seeing that metal band.
Old Mar 24, 2014 | 04:47 PM
442scotty's Avatar
Surprising to see the rust under the weatherstrip on the door. looks likes its the same on the trunk edge as well. They must have missed it. Looks like a nice car though..
Old Mar 25, 2014 | 05:54 AM
Run to Rund's Avatar
In the 1970s I bought a pair of adjustable upper arms from Parts Dept. The bolts at the diff end were on eccentrics.
Old Mar 25, 2014 | 09:00 AM
capstoneclub's Avatar
I know little about 64's, but I dig that ride
Is that straight up and down shifter OEM back in the day? Looks like you might have to reach a bit to shift vs the curved designs from the later 60's models. I agree that the rust is part of the metal edge band behind the door panel. Just a really cool car. I would love to compare the performance of a 64 vs the 70-442's that I grew up loving.
Old Mar 25, 2014 | 08:05 PM
kjr442's Avatar
Kjr442
Good point.
CRH
Jan 30, 2018 09:27 PM
64Olds98
May 5, 2015 06:30 AM
esteo
Oct 27, 2014 07:23 PM
64oldsf85cutlass
Body work
Jul 4, 2014 07:06 AM
