1963 F-85 arrives in Charlotte
Old Apr 19, 2016 | 11:19 AM
  #41
70-442-W30's Avatar
344879M363895
Originally Posted by Ancient Iron
Chevy was the only one with a lock position. A 63 F-85 only had off
This is good to know. Thanks.
I did some research on the car and am finding an option Y69 (Custom Interior) that was available only for the F-85 De Luxe sedan. Does this car have it?
Old Apr 19, 2016 | 11:23 AM
  #42
Your door panels look like the ones in the base DeLuxe interior (though "base DeLuxe" sure sounds like an oxymoron... ).
Old Apr 19, 2016 | 11:31 AM
  #43
70-442-W30's Avatar
344879M363895
Thanks Joe. Cool pic. After seeing the look of the Custom Interior option vs the one I have, I'm not sure I would have paid for the upgrade myself. I like the metal trim panel on the door where the armrest and door release handle are. The seats do look a little better in your pic, but I'm not sure I would lean in that direction just due to that.
Old Apr 19, 2016 | 11:39 AM
  #44
TK-65's Avatar
I know for a fact that 64 A body Oldsmobiles have the LOCK position, so the part about only Chevy having it is wrong.
Old Apr 19, 2016 | 12:02 PM
  #45
70-442-W30's Avatar
344879M363895
Well, my new technique is to leave the radio on and when it shuts off when I turn the key, then I know the key is actually in the off position, which is straight up and down.
Old Apr 19, 2016 | 12:11 PM
  #46
Yes, the OFF position is always straight up and down. Makes it easy to remember.
Old Apr 19, 2016 | 12:25 PM
  #47
70-442-W30's Avatar
344879M363895
True, but I am doing the radio on/off thing just to make sure I have it right. I don't want another dead battery.
Going to pick up my plate next week for this and try to get some miles on it. My father in law said all the car needed was an exhaust and my mother in law had that put on a few months ago. So it's time to see what this car feels like.
Is the recommended tire pressure in the owners manual? I haven't looked yet, but know it has been repainted so any decal on the door got sprayed also I bet.
Old Apr 19, 2016 | 12:42 PM
  #48
Should be, but I can't say that I've actually seen the particular manual.
Please allow me to say: Bravo for even planning to read the Owner's Manual.
Would that others would do the same.
Old Apr 19, 2016 | 12:48 PM
  #49
70-442-W30's Avatar
344879M363895
Thanks. Every time we get a new vehicle, I read the thing the first day. I like reading those a lot. I might not use every option in the car, but I always find out something I didn't know about and the salesperson didn't mention.
Old Apr 19, 2016 | 01:02 PM
  #50
70-442-W30's Avatar
344879M363895
Found the recommended tire pressure for the sedan. It is 22 front and rear. Except for A/C cars which there is an asterisk and it says to increase the front to 24.
Old Apr 19, 2016 | 01:04 PM
  #51
Keep in mind that those pressures are for the original bias-ply tires, and are usually low for softer ride. Modern radials want to be in the 32-35 psi range. I seem to recall that your car has radials.
Old Apr 19, 2016 | 01:06 PM
  #52
Agreed. My 88 specifies about 24psi, if I recall, but I use my "standard" American car pressures of 28 front / 30 rear on it and it rides and handles much better.
The beauty of the radial-ply tire is that it is soft up-and-down, while being relatively rigid side-to-side.
Old Apr 19, 2016 | 01:07 PM
  #53
70-442-W30's Avatar
344879M363895
Good point. So how do I know what to run on this and the W-30 since they are radials? Do you add a certain percentage for radials or just always go for the 32-35? That's what most of my new cars have needed over the years.
Old Apr 19, 2016 | 01:08 PM
  #54
Ancient Iron's Avatar
Your car is an F-85 deluxe, That's why you have the chrome under the rear deck lid and the full length side trim, A base F-85 didn't have those features and a base car had a real plain interior
Old Apr 19, 2016 | 01:10 PM
  #55
We probably cross-posted, but I've always liked 28 front / 30 rear for most American cars, and used that as a starting point to then adjust up or down depending on whether it felt harsh or soft, or whether the tires wore improperly.
Old Apr 19, 2016 | 01:21 PM
  #56
I would love to see a picture of that
Old Apr 19, 2016 | 01:22 PM
  #57
70-442-W30's Avatar
344879M363895
I did know it was a De Luxe. Maybe I didn't phrase it correctly...
Well from the production numbers I have seen for 1963, that De Luxe must have been an easy upsell. At only $2592 base price De Luxe vs the $2457 of the normal 4 door, that was an easy choice. Around 5% more got you all sorts of good options. Plus, the production numbers tell the story at around 9000 of the normal sedan vs over 29000 of the De Luxe.
Old Apr 19, 2016 | 01:26 PM
  #58
70-442-W30's Avatar
344879M363895
OK everyone, place your bets on a build sheet...going to see tonight.
Old Apr 19, 2016 | 01:41 PM
  #59
Yes, but per the page I posted from the dealer brochure, there was a custom interior option only available on the F-85 Deluxe four door, which was the question. His car does not have that option.
Old Apr 19, 2016 | 01:46 PM
  #60
jensenracing77's Avatar
I could be wrong but I don't think there were build sheets or broadcast cars in 63. At least I never heard of one in the 62-63 Jetfire world.
Old Apr 19, 2016 | 01:50 PM
  #61
TK-65's Avatar
Old Apr 19, 2016 | 01:56 PM
  #62
Exactly like what Chevrolet used
Old Apr 19, 2016 | 01:57 PM
  #63
So are there FIVE distinct positions or FOUR? Is it ACC-LOCK-OFF-RUN-START or is it ACC-(LOCK OFF)-RUN-START? My 62 F-85 (which also is NOT a 63 being discussed here, but is in the same 61-63 family) only has four positions of the ignition switch: left, center, right, and spring right. By the way, I just went and checked. I can remove the key in the ACC postion with some difficulty. I cannot remove it in RUN. The key is not worn, as I cut a new one myself, but the lock tumblers may be.
Old Apr 19, 2016 | 02:12 PM
  #64
TK-65's Avatar
Good question. Someone with a 64 has to know.
Old Apr 19, 2016 | 02:13 PM
  #65
According to the 1963 F-85 and fullsize owners; manuals, there are four positions:
Old Apr 19, 2016 | 02:53 PM
  #66
I wonder if the key lock in Tk's picis a one year only thing? It is exactly like all the early '60s Chevy's that my family had over the years. No '63 Olds ever used a lock like that
Old Apr 19, 2016 | 04:43 PM
  #67
TK-65's Avatar
65 is ACC-OFF-START. Ive always thought LOCK was an actual position like old Chevys. I never thought it could be LOCK OFF, which makes sense.
Old Apr 19, 2016 | 07:07 PM
  #68
70-442-W30's Avatar
344879M363895
You were trying to save me some time, weren't you?
Well, I still gave it my best shot. Figured if there ever was one in a car this old then this car might be a candidate for it. Plus I thought it might be good to have for the future owner, because not everyone can bend down and turn a wrench to look for these things. But, it wasn't to be...did find some little details like the carpet tag and a tag under the rear seat. Cleaned the trunk out too...Photos are here:
Old Apr 19, 2016 | 08:50 PM
  #69
Damn, that car's in good shape.
Old Apr 19, 2016 | 09:18 PM
  #70
On a Chevy if you turned the key from run back to off and removed the key you could restart the car without the key. If you turned the key to lock then you need the key.
Old Apr 20, 2016 | 03:58 AM
  #71
70-442-W30's Avatar
344879M363895
And I haven't even detailed it yet. Thanks!
Old Apr 20, 2016 | 05:06 AM
  #72
tru-blue 442's Avatar
Old School Olds
Amazing shape! Nice score.
Old Apr 20, 2016 | 06:28 AM
  #73
holidaysedan's Avatar
I could be interested, had one in the family when new back in the day and always liked them. I started the Blue & Gray Chapter of OCA and have had nearly 20 vintage Olds but never had one of these... it would have been better if still in PA though as I'm only 5 mi N of the NY-PA border!
Old Apr 20, 2016 | 07:19 AM
  #74
70-442-W30's Avatar
344879M363895
Well thanks holidaysedan. You're first on the list then. Let me know what additional pictures you want and I can get them for you and post them here. I will get you pictures of the worst spots of rust. I had a look under the car today and it does look good. Everything greased up like crazy. Gas tank needs further inspection. There was a bit of fuel residue on the top left front. But someone here told me that it could be repaired.
After I get you the additional pictures you want, we can talk price. I just did the out of state title work this week, so it will take a few weeks anyway for the title to come in the mail.
I also plan on detailing the car inside and out and getting some good pictures of that.
Old Apr 20, 2016 | 07:21 AM
  #75
70-442-W30's Avatar
344879M363895
I should also say that there is no fuel dripping from that spot onto the concrete floor. Transmission does leak a little, so seals and/or pan gasket would need addressed. But all gears work fine.
Old Apr 20, 2016 | 08:12 AM
  #76
70-442-W30's Avatar
344879M363895
Took pictures of various items, including the worst areas for the rust. Fuel pump has been replaced recently and the original is in the box and there was also another box in the trunk.
Forgive me for taking so many pics, but I just wanted to give you a good idea of how it is. I did open the doors and looked underneath them. No rust at all. I can take pics if needed. Also, I do have the trim piece that is missing in the pic of the right rear. It was under the driver's seat.
Old Apr 20, 2016 | 08:21 AM
  #77
70-442-W30's Avatar
344879M363895
Those pics are in walk around order, with the driver's front first. Then driver's rear, pass rear, pass front. You probably know that though, but just wanted to point out in case not clear.
Here are the other pics:
Old Apr 20, 2016 | 08:54 AM
  #78
Doesn't look too bad rust-wise, particularly for a 63. Important areas: springs where they attach to floor pan sheet metal, trunk extensions, cabin & trunk floor, rockers, doglegs etc, sometimes whats visible on outside is like the iceberg principle, don't know until you take the fenders &c off. Be much better if still in PA where I could take a look at it in person!
We did have back in the '80s a 1961 Buick Special with their version of the 215, ran like a Swiss watch! Cute little aluminum engine, not a huge lot of torque, however being that the F-85/Special/Tempest bodies were just a stretch of the Corvair body, they were light!
Old Apr 20, 2016 | 09:04 AM
  #79
70-442-W30's Avatar
344879M363895
I will be starting a for sale thread for it and tell everyone there you have first place on it for now. If you confirm one way or another when I get more pics on, just let me know.
Yes, I just saw a break in the weather and decided to go get it. My mother in law needed the room in the garage to sort out some stuff.
Old Apr 20, 2016 | 09:51 AM
  #80
Great car. Wish my 4 speed Jetfire was that nice.
