1961 Starfire engine noise
Old Sep 16, 2014 | 04:39 PM
409/409's Avatar
I have a 1961 Starfire with the original 394 in it. The engine is making a rattling noise at idle I thought may be a water pump or pulley or something. Then it seems to go away when the rpm's are up. Then I notice a "ring" around the harmonic balancer, or close to it that is loose and I can reach in there with my hand (with the engine not running of course) and spin and wiggle it. I guess higher rpm's creates centrifugal force and it stops rattling.What is this and how do I fix it? Also will the radiator and condenser have to be removed to fix it?
Thanks so much for any advice.
Old Sep 16, 2014 | 05:22 PM
Oldskeeper's Avatar
Sounds like your harmonic balancer has seperated which means the rubber between the ring and pulley has dried out. They can be revulcanized and then they work fine, Fusick does this.
I would place a sheet of plywood between thew pulley and the rad so you don't hit it with a wrench or other tool.I have removed the pulley to replace the front seal without difficulty.
You might want to replace the timing chain and sprockets while the pulley is off.
Steve
Old Sep 17, 2014 | 08:52 AM
Depending on the puller, you may need to remove at least the radiator.
Old Sep 18, 2014 | 05:14 PM
409/409's Avatar
Are the 3 pulleys a part of the balancer and how do you keep the engine from turning when removing the big bolt in the middle???
Old Sep 18, 2014 | 05:16 PM
409/409's Avatar
Also I am in desperate need of a gas tank for a 1961 Oldsmobile Starfire!!!
Old Sep 18, 2014 | 05:23 PM
In the back of my mind, a little voice is saying that the pulley is part of the balancer, but I am not a 394 expert.
The best way to remove the bolt is with an air wrench, which you will probably not be able to fit without removing the radiator.
If it's important to leave the radiator in place, then you can get a length of rope about ⅜" in diameter and feed it into one cylinder (leave a bit hanging out ) - the rope will prevent the engine from turning when the piston presses up against it.
You will need a L-O-N-G wrench to get that bolt off.
Good luck!
Old Sep 18, 2014 | 05:24 PM
No, I believe the pulley bolts on separately. A 1/2" impact works great on that bolt as it is torqued very tight.
Old Sep 18, 2014 | 06:06 PM
Sorry. Just found the reference that the little voice in my head was talking about, NAS's "Brought a '61 Back" thread:
Originally Posted by NAS Backyard
... I had the 2 groove balancer rebuilt by Dale Mfg for 130.00 but since found a 3 groove one since I'll be running AC.
I sure hope the 63 394 AC 3 groove pulley works on my 62 394 !!! Because I just had Hess Bro. send it strait to the harmonic balancer rebuilder www.hbrepair.com.
Old Sep 18, 2014 | 07:05 PM
Haha, maybe I should listen to your voices instead of mine.
Nov 18, 2014 09:59 AM
starfire
Nov 5, 2013 08:37 AM
Don R.
Dec 8, 2012 08:21 PM
tpawlik
Sep 27, 2010 07:02 AM
Redog
Mar 7, 2008 02:34 PM
