1959 Oldsmobile Questions
Old Apr 9, 2015 | 11:04 AM
Don R.'s Avatar
I am interested in a 1959 Olds 98 and need a 59 expert to answer some general questions:
* I see this is an X-frame car, does it use a 2-piece driveshaft with a center bearing?
* They refer to the transmission as a Jetaway, is that the 4-speed old style Hydramatic?
* I don't see a brake booster or master cylinder mounted on the firewall, where are they located?
* How much mechanical interchangeability is there between the 59 and other years?
Thanks in advance for your help.
Old Apr 9, 2015 | 11:35 AM
Oldsmaniac's Avatar
Yes an X frame with 2 piece driveshaft.
Jetaway but not the cheap 2 speed Jetaway used on the later Cutlass. It is a 3 speed and reverse trans and better than the Slimjim.
Brake booster mounted way low almost under firewall.
59 trim is unique to 59 and the 98.
Old Apr 9, 2015 | 11:59 AM
Oldsmaniac's Avatar
Some trim pieces interchange from the Super88 in 59 to the 98. Mechanicals from the 60 Olds interchange with the 59 but the brake master and booster does not. Sheetmetal is olds 59 only and the wheelbase is longer on the 98 and is made up in the quarters, Rocker and rear wheelwell moldings are 59 98 only units and are impossible to find.
Old Apr 9, 2015 | 01:06 PM
Tedd Thompson's Avatar
What the others have said except the Jetaway is a 4 speed not a 3 speed...Tedd
Old Apr 10, 2015 | 10:29 AM
Don R.'s Avatar
Thanks. Another question, is the 59 wheel bolt pattern the same as my 63? Does the 59 use the left hand thread bolts on the drivers side?
Old Apr 10, 2015 | 10:48 AM
Charlie Jones's Avatar
Phantom Phixer
Yes and yes
Old Apr 11, 2015 | 09:10 AM
Don R.'s Avatar
Thanks for your help on this, unfortunately the 59 I was interested in got away.
Old Apr 11, 2015 | 10:13 AM
twintracks's Avatar
I hate it when that happens.
Old Apr 13, 2015 | 12:14 AM
lazy394's Avatar
Hopefully it went to a good home
Old Apr 13, 2015 | 06:18 AM
Oldsmaniac's Avatar
Here is a pretty nice 98 coupe!
http://www.ebay.com/itm/Oldsmobile-N...0#ht_566wt_886
Old Apr 13, 2015 | 09:26 AM
Don R.'s Avatar
It was a bubbletop coupe like the ebay listing at a local consignment dealer. REALLY nice exterior and good original interior. I looked at it online every now and then for 6 months and finally decided to go look at it - called and found out the owner had JUST traded it for a 59 De Soto! Nobody's fault but my own.
dcalk05
Aug 7, 2013 10:12 AM
bccsrc
Jul 27, 2007 02:36 PM
Cesar Malta
Jul 11, 2007 08:24 PM
Motorama
Sep 22, 2006 12:17 AM
dcalk05
Aug 17, 2004 07:10 PM
