12V HEI Source
Old Jul 18, 2011 | 07:25 PM
dallasite21's Avatar
12V HEI Source
So I have run my 12v HEI wire from the Ign connector in the block to my HEI, however i am notgetting a full 12V. Is bthere a tolerance that you can be within where it is still ok, or do you absolutely have to have 12V? I was at like 11.64 volts not sure why. When I tested straight from the battery I was over 12. Would the difference between 11.64V and 12V be enough to keep my car from starting?
Old Jul 19, 2011 | 06:39 AM
dc2x4drvr's Avatar
The voltage drop isn't the reason your car won't start..
Old Jul 19, 2011 | 11:10 AM
jag1886's Avatar
Are you saying you removed the resistance wire, pulled the fuse box apart, removed the connector pin and replaced it with a standard wire and still don't have 12V?
Old Jul 19, 2011 | 01:00 PM
Beob's Avatar
Are you getting a spark at the plugs?
Old Jul 19, 2011 | 07:45 PM
Yes.. i ran a whole new wire from the fuse box ignition terminal and Im getting 11.64. I did however get it to start today, It seemed like it was getting no spark thn all of the sudden it fired up.. Thanks all for the help.
Old Jul 19, 2011 | 07:55 PM
You should check voltage at each accessible terminal from the battery through the fuse box, to the distributor, and find out whether you can identify a particular spot where that voltage drop is occurring, then clean around those terminals to correct it.
joepenoso
Jun 4, 2014 01:56 PM
455cutlass1969
Apr 19, 2014 04:21 PM
Aceshigh
May 23, 2010 08:06 PM
stuhes
Jan 31, 2010 02:15 PM
Pfiffle
Mar 7, 2008 12:53 PM
