12 bolt rear end locks up in reverse
Old Feb 28, 2014 | 06:08 AM
Dbechtel71's Avatar
hello everyone, my 12 bolt 3:23 rear end will not spin in reverse. now this rear end sat for a long time. I took off rear pan and cleaned out old gear oil and sprayed the gears clean and put new oil in. now when I try to spin in reverse direction the gears are locking up. I know when I rolled this car off the trailer it worked fine. what could be the problem? I don't understand why it wont spin. thanks
Old Feb 28, 2014 | 06:45 AM
507OLDS's Avatar
Is this in a car,or out,and spinning by hand? Is there any debris on the teeth?Even a papertowl can cause it to bind real bad.Has it ever been serviced or rebuilt?
Old Feb 28, 2014 | 07:44 AM
halfmoontrail's Avatar
In my '77 Trans Am, similar problem turned out to be brake shoes binding. Disregard my comment if this is not a complete rear end drum-to-drum.
Steve
Old Feb 28, 2014 | 09:29 AM
Dbechtel71's Avatar
the rear end is out with no brake hardware. I turn it by hand but sometimes I can kinda finesse it to go but somethings is obviously wrong. I guess im gonna have to ruin the $20 gasket and get into the gears again.
Old Feb 28, 2014 | 09:30 AM
Dbechtel71's Avatar
I don't believe its been serviced. the car had only 80k on it. I was wondering if when I sprayed it with carb and or brake cleaner that maybe that ruined something
Old Feb 28, 2014 | 10:07 AM
Professur's Avatar
Very few bushings and bearings are fans of degreaser.
Old Feb 28, 2014 | 01:22 PM
Dbechtel71's Avatar
did I ruin it then? what can I do to fix it?
Old Mar 2, 2014 | 05:45 PM
Dbechtel71's Avatar
We'll I pulled the pan off and found a rag I used to clean it still in there. Stupid!!!!!!
Topless72
Nov 22, 2020 11:01 AM
65OldsDynamic
Aug 6, 2015 12:22 PM
350TurBRO
Sep 12, 2014 11:52 AM
dan1s
Sep 23, 2008 01:53 PM
mcutlass1969
Drivetrain/Differentials
Mar 6, 2008 10:24 AM
