12 bolt questions
Old Jan 10, 2009 | 12:33 PM
Rogers Hurst/Olds's Avatar
12 bolt questions
I have 12 bolt type(O) 28 spline axles.Have problems finding posi unit that will work in it.I have bought 2 different ones on ebay, 1 was 8.2 with 3.08 gears and pinion.it will bolt in but the pinion is different.I also bought 8.5 posi unit but my factory 278 gear wouldn't(10) bolt up to it.I traded it for a set of B heads.Anyone know of anything that will work without changing the whole rearend,and not to expensive.Thanks for any suggestions!!!
Old Jan 10, 2009 | 05:10 PM
64Rocket's Avatar
"Reider Racing" has them. It is a 8.8 Ford unit machine to fit. I've done 2 of them and they work fine.
Gene
Old Jan 10, 2009 | 06:20 PM
No, you don't. You have a TEN bolt Type O. Contrary to popular believe, the number of bolts on the cover is irrelevant. The ten/twelve bolts designation refers to the number of bolts holding the ring gear. On Chevy axles, the number of bolts on the ring gear and on the cover happen to be the same. On the Type O, they are not. A true twelve bolt axle has twelve bolts holding an 8.875" ring gear to the carrier. The Type O has ten bolts holding an 8.5" ring gear. You need a carrier for a Type O. I was not aware of the modified Ford carriers being modified to fit. That is pretty cool.
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
