Turn Signal not working left side 72 cutlass
Only 2nd time on this forum. Have a 72 Cutlass S. All 4 sides work when using Hazards lights. Turn signals work front and back on right side. On left side turn signal lever will lock as normal and the front/back lights come on as well as dash indicator, but they will not blink unless the turn signal switch lever is moved up and down. The only other thing is that the flasher on hazard is blinks faster than the right side turn signal blinks. I know that the 2 systems have different flashers. Could it be a weak flasher or problem with turn signal switch or ??????.
Thanks Herv
Thanks Herv
Thanks Herv
Thanks Herv
Joe
Thanks, I'll list this as dumb on my part. When I saw light on the rear left I did not look down low enough to see that the bottom brake light was not on. Removed 4 screws , replaced bulb, installed 4 screws and I'm back in business.
Thanks Herv
Thanks Herv
1badcut
Feb 13, 2011 06:27 PM
cbogartjr
Aug 3, 2008 06:18 AM
