Blower Motor Pops Fuse on High Speed
Old March 11th, 2014, 06:58 PM
johnnyhawthorn's Avatar
I have a 1970 Cultass Supreme convertible with A/C. When the blower motor is set to high speed, it pops the in-line circuit breaker. This would indicate to me that there is a short in the blower motor. The blower motor relay was replaced and checks out OK. From looking at the diagram of the blower motor circuit, there blower motor relay is the only thing in-between the blower motor and the horn relay when it is set to run at high speed. I'll put this out to the forum for suggestions on what to test/replace.
johnnyhawthorn is offline
Old March 11th, 2014, 07:33 PM
Octania's Avatar
That's one possible cause.
Faulty relay is another.
What say you measure the current draw?
I imagine the blower motor is a permanent magnet type? [Could be wound stator instead] If the magnets are weak, the motor will draw excess current but have reduced output. Or, the armature / brushes may be defective. In any event, if the motor is drawing excess current, replacement is the answer.
Octania is offline
Old March 11th, 2014, 07:59 PM
Just the facts...
BILL DEMMER's Avatar
check your high speed blower wiring for chafing. check the relay connector for melted plastic(common).
lubricate the bushings of the motor.
the bushings may be worn. i've seen a blower still run with the shaft worn through the back bushing and case.
you may have a partially shorted armature. one thing that can cause this is not having the blower bypass hose connected, which will cause the armature to overheat, burning the insulation from the windings.
i highly doubt there is a problem with the permanent magnets inside the motor.
bill
BILL DEMMER is offline
Old March 11th, 2014, 08:18 PM
Bill's got all the bases covered. My money's on tight bearings or a missing cooling tube.
MDchanic is offline
Old March 12th, 2014, 05:10 PM
jag1886's Avatar
When I work on cars that usually meant the blower motor was on it's out.
jag1886 is offline
Oldscutty72
December 28th, 2015 01:56 PM
mmurphy77
June 17th, 2014 12:49 PM
72Cutlass_Sunfire_Yellow
May 21st, 2013 06:31 AM
krashx7
December 19th, 2012 01:43 PM
ao177snipe
January 30th, 2012 03:40 PM
Quick Reply: Blower Motor Pops Fuse on High Speed
