1990 Olds 88 royale brougham cooling fans not working
Old Sep 30, 2013 | 02:57 PM
Dshelvy's Avatar
Ok I know its not a classic but it is an Oldsmobile. Any ways my cooling fans aren't coming on, I've had this problem before less then a month ago. I replace all 3 relays and the coolant temp switch, it worked fine once I replaced the switch. Well now my temp gauge(which runs off of a different sensor) says my car is over heating and if I pop my hood, my fans are not on. I know the fans are good, and I highly doubt that my switch is bad in less than a month. Has anybody ever had a similar problem? Thank you for your help in advance.
Old Sep 30, 2013 | 03:14 PM
I'd start troubleshooting connectors and then components. Possibly a loose connection.
Old Sep 30, 2013 | 05:01 PM
Dshelvy's Avatar
If I jump the relay it works so the wiring is intact. So either my gauge or sensor is lying to me or there is something wrong with my ECM or the wiring going from the temp switch to computer or from the computer to the relays. The computer grounds the relays and that is how it activates the fans which I thought was weird. I didn't imagine it using the ground to activate the relay to engage the fan.
Old Oct 1, 2013 | 02:14 AM
rustyroger's Avatar
'87 Delta 88 Royale
Seems odd the fan operates via the computer, my '87 Olds Royale doesn't.
If you run an ignition live to the fan switch and have the relays running direct from the battery you will bypass the ecm.
I had to chastise the editor of the UK publication "Classic American" for describing H bodies as "nasty", he had the grace to publish my letter though. As I said in my letter perhaps H bodies aren't classics..... yet.
Roger.
STLOLDS
Apr 1, 2016 03:47 PM
brilig
Aug 23, 2014 03:11 PM
nativemona
Aug 1, 2014 12:26 AM
lunaboy
Jun 11, 2014 04:30 PM
Stevec
Oct 29, 2013 07:47 PM
