flat wire harness in floor on 64 F-85
Old Sep 2, 2013 | 09:36 AM
therobski's Avatar
Guys to they re-pop the flat wire harness that goes across the floor to connect the front to the rear harness or can i fix this one pictured.
Old Sep 2, 2013 | 11:27 AM
Is that the only bad spot?
Old Sep 2, 2013 | 11:53 AM
therobski's Avatar
Yes the rest is almost perfect. In the meantime I am going back out to shop and try and splice in piece of wire and solder it.
Old Sep 2, 2013 | 11:55 AM
Octania's Avatar
Maybe procure a good used one?
Old Sep 2, 2013 | 12:18 PM
That's what I would do.
Make a good connection and insulate it properly, and it will stay under the carpet for another fifty years, with nobody the wiser.
Old Sep 2, 2013 | 01:19 PM
X2, I would also just opt to repair that one.
Old Sep 2, 2013 | 02:47 PM
therobski's Avatar
having afew issues
I am not best at soldering although not "Rocket" Science but I stripped away about an inch of the flat wire-it's flat copper and having trouble soldering it to a braided wire-using a green piece of 14 gauge. I think tomorrow I am going to start over with a new piece of wire and separate the strands and kind of twist them around the flat copper piece and then solder it.
Old Sep 2, 2013 | 03:12 PM
Sometimes you need to scrape the coating off the copper lightly with an excacto knife before soldering. Tin both sides lightly and then solder then together.
Old Sep 2, 2013 | 03:16 PM
therobski's Avatar
I will make sure I do that and when I start over tomorrow I will let you guys know the results.
Old Sep 2, 2013 | 03:17 PM
Boiler_81's Avatar
Old oxidized wire is tough to solder. You to Radio Shack and get a little tube of flux for electical soldering. Do Not substitute plumbing flux.
Old Sep 2, 2013 | 03:26 PM
If worse comes to worst, you can always run another wire the entire length of the cable, and connect it to the plugs on each end - not pretty, but, again, who's gonna see it?
Old Sep 2, 2013 | 03:31 PM
Octania's Avatar
Feeble memory says that the conductor is aluminum, not copper
which you will not solder to.
Alternate wire is a good solution, end to end.
Is there any chance that you have an unused conductor, and can swap, leaving the corrupted one unconnected? Or maybe it's already unused?
with my luck it'd be the brake lights
Old Sep 2, 2013 | 03:40 PM
Ah, the sixties, days of aluminum wire and all-electric houses...
... Those were the days.
Old Sep 2, 2013 | 03:57 PM
oldstata's Avatar
Justin
Hey rob JATA is parting out a 64 four door he might have this . Located in Florida he usually ships priority mail
So it might not hold you up to badly
Old Sep 2, 2013 | 06:10 PM
gearheads78's Avatar
car guy
I might have one from a 67 Chevelle I parted out.
Old Sep 6, 2013 | 02:52 PM
therobski's Avatar
I ran over to "Gearheads" and the 67 Chevelle is alittle too long and the connectors on the ends a little bit different. So I need this part, most likely 64-66? I will get a hold of JATA. Thanks
Old Sep 6, 2013 | 04:53 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Intermediate harness
If a 66 /67 Intermediate harness is the same .I have a few.
Ron Roth
Old Sep 6, 2013 | 06:32 PM
Is it really aluminum?
Old Sep 6, 2013 | 07:00 PM
vix6t4's Avatar
I had the same problem, looked nearly identical to your picture. The flat harness in mine is copper, and it is a 1964 convertible. I also used 14 gauge wire, unwound the strands into a sort of fan shape, tinned the ends of each, held it in place with small alligator clips and soldered it together. I also used the correct flux for soldering wire. I peeled the flat wiring back so I could get enough heat shrink tubing on it, then lots of electrical tape. Mine was broken about where your feet go so I didn't want it to short on the floor. Vic
Old Sep 6, 2013 | 07:07 PM
Octania's Avatar
i FOUND A BOX OF '65 WIRING in the garage
damn caps lock...
'65 *VISTA*
sorry....
Old Sep 11, 2013 | 05:26 PM
JATA's Avatar
I replied to u when you originally asked for the flatwire on the other site (past weekend)....never heard back from you. I have several all from 64/65. Just depends on what style you have as the length and connectors can be different.
delmontcrusier
Apr 2, 2012 06:28 PM
69442
Nov 29, 2009 08:50 PM
jensenracing77
Sep 4, 2009 05:46 PM
1973olds98
Jul 27, 2009 07:51 PM
