Left side signals won't flash 1970 Cutlass S
Old Jul 23, 2013 | 05:16 PM
coldfire's Avatar
Front and rear bulbs all work - they come on when the lights are turned on, and they will light up if I click the signal lever down, but they stay on, no flashing... so I've been manually signaling every time I go left lol
The right side ones function perfectly
Old Jul 25, 2013 | 02:00 PM
coldfire's Avatar
Anyone?
Don't both sides run through the same relay?
Old Jul 25, 2013 | 02:13 PM
455man's Avatar
I'll bump this cause I have a similar issue on the same side but front only. I havent had a chance to get into the wiring yet. I tried cleaning the connections good but it didnt help.
Old Aug 2, 2013 | 01:02 PM
coldfire's Avatar
I don't know if this will help anyone diagnose, but I discovered that the front will only signal if the lights are off... once the parking lights or headlights are on, it will be ON but won't flash even with the manual flashing (the back one still will if I manually move the signal arm up & down)
Again, the passenger side ones function perfectly in all conditions (lights off, parking lights only, headlights on)
Old Aug 3, 2013 | 06:33 AM
This is usually a sign of a bad ground. Check the ground (or socket) at the front light. Also, check ALL the bulbs on the side that doesn't work. Keep in mind that the 1157 bulbs have TWO filaments, one for parking lights and one for brake/turn. The turn signal circuit is designed to not flash if a bulb is burned out, but you may have two different problems now, a burned out bulb and a bad ground. Also note that the brake and turn lights at the rear use the same filament, so see if all the brake lights work, both with the parking lights on and off.
Feb 26, 2015 02:17 PM
Beeks69
May 8, 2014 07:13 AM
72cuttys
Mar 30, 2014 07:43 PM
defiant1
Sep 9, 2011 09:29 PM
gearheads78
Mar 20, 2009 05:01 PM
