Another sparkless ignition
'68 Delta 455...
No ignition problems before the motor was taken out, now it wont start...no popping, spitting, its like all the plugs are disconnected...not fuel, I can see the acellerator jets pumping, plus you can smell the gas after cranking it.
-replaced coil- with a jumper lead I get a nice painful spark out of the HT lead
-even without lead coil gets 12v-8v (depending if points are sitting open I think) Not sure about during cranking--reason for jumper lead
-replaced primary wire from dist to (-) coil..checked the wire no resistance
-measuring resistance from primary clip to dist body I get no resistance with points closed and infinite with them open
-also tried a new set of points still nothing-tested them as well and get the same values
-checked center electrode in cap, no resistance
-same for rotor electrode
At this point, is it safe to say that the fault is within the distributor somewhere?
Not sure if I missed something, searched around here and found these things to check
Possible the dist body isn't grounded? don't remember if I checked that--been a long day..
Maybe a bad condensor--any way to test?
Points are set as close as I could to .019" dwell I'm not sure about--is there even a way to set without it running?
Had it lined up as best I could at TDC on cylinder 1 to start..every other time the rotor was marked where it was and replaced the same way--but even if the timing were way out wouldn't I get something?
I replaced it with a 6 ga wire, plus added another that goes from the front of that head to the frame (one end of the ground strap that goes to the control arm) also made sure all connections were shiny
also the spark I get from grounding the hot coil is pretty good bright and blue
The new points set had a new condensor on it, but it's not impossible that it was bad too.....
But, the condensor that sits on the coil--that's just for radio interference which I don't care about at this point--is that useable to test out? If so how would it be hooked up?
I am going to line everything up again however once I'm ready to give it another go
Yes, that I need to get
crazy idea, but it is possible or even a good idea to- connect everything, but leave the dist uninstalled but grounded to block via cable, install one sparkplug lead grounded to verify spark, and spin it by hand?
Just brainstorming-- might be easier on the motor internals
If you used a intergaded points/condensor, toss it.
I HATE those things, but that's me. I never had any
luck for very long with them. Standard, if you can find them
or better yet, Delco Remy.
My money's on the condensor. I am not sure if you can use
the radio condensor on top of the coil that is designed for
radio interferance or not. Check O'rileys, or Napa, you maybe
able to get the stand alone points/condensor. Good luck
and let us know how it all turns out.
I have the integrated points condensor... Delco remy
funny thing was I went to get the points yesterday and had the separate pieces but got the integrated piece bc that's what was already in the dist....
Getting a dwell meter tonite, I'll
pick up points too
pick up points too
I would install the old point set since it worked before just as a test. I've had the uniset fail in the past. and troubleshot with a known go set. I also carry the old known good set in my trunk with an old set of wires, cap, rotor, and plugs as emergancy spares.
Only the coil wire running to the cap. Also with your jumper to the coil, in order to turn the motor off it will need to be disconnected.
I have two cap wires, both have contnuity, as well as the plug wires, so hopefully this stripped down ignition circuit will work with everything new, and now I have every part doubled up (some tripled haha)
btw the look on they guys face at autozone was priceless when I asked for a dwell meter
This isn't rocket surgery. The coil will throw a spark any time there's 12 V and you momentarily ground the - post.
So if I have this correct.
1) Your coil will spark if 12 V is applied and you ground the - post
(make sure nothing else is wired to the - post , ie tach, grounding it will kill ignition)
2) You know the distributor is turning
(Do you know if the points are opening closing? You can crank engine by hand and confirm with ohm meter)
Now you can turn ignition on, crank motor by hand, look for spark directly from coil (use a spark checker directly off the coil/distributor wire, ground the other end)
If that shows spark and yoour not getting anything at your plugs, it's in your distributor cap/rotor.
Check the tab that connects the rotor to the cap input, look for carbon tracking or cracks in the rotor/cap. You can get carbon tracking through the rotor to the distributor shaft.
Good news is that it was one of the parts that I replaced so now it fires...just gotta get it all lined up to run and she should be rolling soon! Was just glad it was an actual part in need of replacing and no something I did incorrectly (besides trusting 20+ yr old parts) thanks for the walk through guys
coldwar
Feb 20, 2014 01:09 AM
