Computer controlled distributers
Old Feb 24, 2012 | 12:42 PM
Dean Eechaute's Avatar
Are some of the later year Olds engines equipped with a computer controlled distributer. These are commonly refered to the the small cap HEI. If this exists, would it work on the older engines like the 400, 425 or the 455? I am looking at a computerized throttle body injection system that can control the ignition system without have to fork out alot of green for a MSD system. Thanks, Dean
Old Feb 24, 2012 | 02:36 PM
cfhcar's Avatar
Smile
i was told computer contorl carb 307 dist. 82-87 sould work. that what i,m going to use when i do tbi on 71 delta with 455. this is a big cap one (COIL IN CAP)
Old Feb 24, 2012 | 03:23 PM
I have a HEI distributor from a 350 and that will not work with the original style OB4 intake I have (square port intake). I guess what I need is a 88 thru 90 307 style which should be the small cap HEI that is computer controlled with a separate coil (not in the cap). Dean
Old Feb 24, 2012 | 04:46 PM
Olds never used the small cap computer-controlled distributors. The distributor for the CCC system (1981-90 307 motors) is the same size and uses the same cap as all other Olds HEI units. The only external difference is that there is no vacuum advance can since the computer controls the advance curve.
Old Feb 26, 2012 | 12:19 AM
Thanks, Dean
skryla
Jan 14, 2015 07:03 AM
Daverd
Nov 3, 2013 07:03 PM
Greg Rogers
Apr 2, 2013 06:38 PM
84oldsDelta88
Aug 1, 2012 09:25 PM
marcar1993
May 1, 2007 11:35 AM
