brake light issues? 1975 olds delta 88
Old Jul 26, 2011 | 03:01 PM
arod40's Avatar
pull light switch front lights come on, left and right signal light work and brake light work as well when i press brakes, but no rear lights or dash light when i pull light switch for night driving. not sure where to start all fuses look good. any ideas???
Old Jul 26, 2011 | 03:08 PM
jaunty75's Avatar
Defective headlight switch?
By the way, can you be more specific about the rear lights? You say the turn signals work. Do you mean both front and rear turn signals, or just front? Also, does the license plate light come on?
Does the dome light come on as it should when you turn the headlight switch all the way to one side? Does the dome light come on when the doors are opened?
Old Jul 26, 2011 | 03:45 PM
If I recall, some headlight switches have the front and rear lights on separate terminals.
The instrument lights are on another terminal all together.
I agree that a bad switch, with a dirty internal contact, could be to blame.
You can disassemble the switch pretty easily, but since they're available from your local parts store for about $12, it may not be worth the effort.
jaunty75
Apr 12, 2015 05:53 PM
andrewk94
Dec 9, 2014 12:17 AM
chrisntam
May 27, 2013 08:14 PM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
cohassetgold
Oct 13, 2012 06:30 PM
