2 electrical questions.
Hello.
First, my car is a 1970. Original rally pack package.
car is after a complete frame off.. started driving the car 2 weeks ago after a 5 years restoration.. all excited
now for the questions..
1) where is the original wire that needs to be connected to the tach in the engine bay.. i can't seem to find it.. (i have 2 spare wires.. they don't seem to react.. and before i took the car apart everything worked.)
2)Have a weird problem with tail lights...
First.. the turn signal doesn't work at all.. not to the right, and not to the left..
When i hit the brakes, only one side turns on.. when i turn on hazard lights.. both sides flash.. which means the bulb is ok...
If i play with the turn signal.. the "good" brake light moves from RH to LH..
ummm... what's going on?!
Thanks for any help.
I would really appreciate it.
1) the tach wire is brown and should break out of the engine harness with the coil wire...chassis manual pg. 15-31,2,3... 2) Check the yellow and green wires for bad connections for the sig lights...
You MAY have a bad signal light switch.
The signal light switch does all the work to get brake lights, signal lights, and emergency flashers (2 separate flasher units) out of only 2 light bulbs (or 4, but wired as 2). A loose contact can do stuff like this.
I'd check the diagram, disconnect the harmonica plug on the column, and use test leads to be sure that the lights are working the way they should (correct bulb and filament to correct wire). This should exclude the weird "bad ground" or "2-filament bulb in the socket funny" gremlins.
