71 olds442 convertible electrical questions
Old Mar 14, 2013 | 08:49 AM
oldsdriver1218's Avatar
Hi I have a 1971 olds 442 convertible.The cars wiring under the hood was all chopped up mostly made up of yellow wiring. I have a few ?. I was hopping someone can help me out first the starter wires ( I bought all new wiring harnesses from yearone ) there is a yellow and a purple when the started is installed can you tell me witch wire color is next to the block I may have them reversed. 2nd I have 3 connectors they are as follows one is a double male with solid green and green with white stripe it also has resistors.Next is solid green male connector runs towards front of engine I think this is for water dummy light.Then there's a round two wire green with white stripe and black with brown or orange stripe(sorry a little color blind )Last there is a block that goes on the fire wall behind the brake booster it has large red wire in and red out. I cant remember where these wires run to and from I think one end is connected to the horn relay but not sure I have included pictures of all the connectors any help will be appreciated.
Well I tried to upload multiple pictures with no luck I hope my description will be enough the one picture I could upload is the hardest one to describe hope someone can help thanks
Last edited by oldsdriver1218; Mar 14, 2013 at 12:04 PM. Reason: correct spelling and punctuation
Old Mar 14, 2013 | 09:20 AM
First, I would look around for a bunch of lost punctuation - it looks like it somehow fell out of your post.
I will answer your questions as best I can decode the approximately 230 words of unpunctuated test you deposited.
1. Starter solenoid: Purple wire to "S" terminal, Yellow wire to other terminal.
2. Green wires through funny ~1x2" black box to single wire and terminal: Probably under-pressure safety wiring for A/C compressor.
3. Green / White and Black / White wires probably TCS switch.
4. The pictured item is the circuit breaker for the power windows.
I would strongly recommend checking your wiring with the schematic in the Chassis Service Manual.
If you don't have one, it would be wise to buy one, on eBay, for instance, and you can download a copy for free as well from WildAboutCars.com.
Old Mar 14, 2013 | 09:40 AM
The car never had power windows could it be for the convertible top. If so does one end connect to the horn relay. And the other to the top switch. As for the starter input thanks. The wiring harness is suppose to be for a non a/c car but that"s what it looked like to me because of the resistors. I will check the web site you gave. I DID NOT THINK PUNCTUATION WAS THAT BIG OF A DEAL BUT THANKS FOR YOUR TIME IT IS APPRICIATED
Old Mar 14, 2013 | 11:27 AM
Yes
Yes
And you would be mistaken. Read the book "Eats Shoots and Leaves". The statement "Eats, Shoots, and Leaves" means something VERY different from "Eats Shoots and Leaves". The former refers to my uncle Guido, the latter to a panda. The difference is a couple of "no big deal" commas.
Seriously, you're asking people to take the time to help you. The least you can do is make it easy for us to read your question.
Old Mar 14, 2013 | 11:52 AM
I never realized that car guys were so into punctuation. Ill make sure that any other questions I ask are punctuated properly thanks for your time
Old Mar 14, 2013 | 12:07 PM
I did my best to fix spelling among other things hope this makes it easier to read. Sorry for the mistakes.
Actually, we're into correctly understanding the question so we can provide a correct answer. This isn't a "car guy" thing, it's a life thing.
Old Mar 14, 2013 | 12:24 PM
That's cool thanks did you get a chance to look it over I made changes but don't know if it's better or not
Last edited by oldsdriver1218; Mar 14, 2013 at 12:25 PM. Reason: added a little more
Oldsguyhill
Mar 20, 2014 08:30 PM
HemiCudaKidd
Mar 5, 2012 06:22 AM
w-31cutlass
Nov 9, 2010 04:53 AM
64starfire
Apr 4, 2010 07:51 PM
rock3390
Dec 11, 2009 08:11 AM
