455 igintion wiring
Old Aug 4, 2010 | 06:34 PM
1970_442's Avatar
455 igintion wiring
im having trouble wiring my 455. where does the wire on the bottom of the dist connect to? im used to diesels
Old Aug 4, 2010 | 08:21 PM
Frankenstien's Avatar
Ok, here you go, hopefully this helps.
The bottom of the distributor should plug directly into the cap of the distributor. But it depends on what kind of Distributor that you have. The Dist I am referencing is the HEI Distributor. The wires at the base should plug in closest to the cap.
Old Aug 4, 2010 | 08:25 PM
1970_442's Avatar
i have a points style distributor. there is one wire coming out of the bottom.
Old Aug 4, 2010 | 08:45 PM
Blk71SX's Avatar
from the coil to the points
Old Aug 4, 2010 | 08:47 PM
1970_442's Avatar
neg or pos?
Old Aug 4, 2010 | 08:57 PM
extreme1's Avatar
wire from distributor goes to negative on the coil.
pcard
Apr 10, 2014 08:55 PM
scooter123
May 2, 2013 05:46 AM
scooter123
Apr 29, 2013 05:40 AM
72 Olds Project
Jun 6, 2011 06:47 AM
