455 igintion wiring
Ok, here you go, hopefully this helps.
The bottom of the distributor should plug directly into the cap of the distributor. But it depends on what kind of Distributor that you have. The Dist I am referencing is the HEI Distributor. The wires at the base should plug in closest to the cap.
72 Olds Project
Jun 6, 2011 06:47 AM
oldzy
Sep 10, 2009 05:23 AM
