49 radio needs a replacement
Old March 24th, 2010, 03:48 PM
oldbill's Avatar
Radio in my 49 last played a tune 3 years ago... I would love to find some one to fix it but if that fails I would like to convert to something that still looks like the original.. I saw a radio replaced by an MP3 but I don't really want that. AM only would be fine. Just show me the Music..
oldbill is offline
Old March 24th, 2010, 05:34 PM
jaunty75's Avatar
I'm guessing it has tubes? Have you tried replacing any of them? They're actually surprisingly easy to get and not usually all that expensive.
You would need a tube tester to actually test the tubes, but it's probably just as well to replace them all.
Here's a couple of possibilities:
http://akronantiqueaudio.net/splash.asp
http://www.tubesandmore.com/
I've had dealings with the second one in the past, and they were fine.
Make a list of the tubes you need with each one's number (12AX7 and like that) and then get on these websites or call them up and see what they have.
jaunty75 is offline
Old March 25th, 2010, 03:28 AM
oldbill's Avatar
Old Radio Tunes
Thanks, I'll give them a try. I had been told by locals that none of that stuff was available. I took the radio out and took the bottom off and the tubes are all right there where I can see them and read the numbers. I would be nice to keep it original.
oldbill is offline
Old March 25th, 2010, 03:38 AM
jaunty75's Avatar
Darn those locals!
Keep in mind that it may not be just the tubes or even the tubes at all. I've brought back to life a few old radios over the years, and while new tubes do the job most of the time, it's also possible that new capacitors or other components are needed. But it certainly should be possible to return your radio to working condition as is as opposed to replacing its internals with modern circuitry.
jaunty75 is offline
Old March 25th, 2010, 04:33 AM
Past Administrator
Oldsguy's Avatar
Another problem may be the old paper style capacitors, they just don't hold up over time and their values have changed so much that the radio may work, but very poorly. There are places that will repair your radio to like new condition, or upgrade it whichever you wish. I will see if I can find the link to one of them.
Here is one of them.
Oldsguy is offline
Old March 25th, 2010, 04:41 AM
Past Administrator
Oldsguy's Avatar
By the way, I think I missed your previous posts and never welcomed you to the site. It is kind of late but welcome to the site. Ever get your other projects finished (brakes, suspension)?
Oldsguy is offline
Old March 26th, 2010, 03:48 AM
oldbill's Avatar
I looked at the Bobs Radio site and I noticed that he will NOT guarantee any radio on an 8V system! I am running an 8Volt battery in my 49. Its about the only way to be sure it will start! I just wonder what damage that will/has caused to the radio? It seems to me that some kind of a stepdown transformer could cut the 8V back to 6V if it really damages the radio?
oldbill is offline
Old March 26th, 2010, 04:02 AM
Destructor's Avatar
Keep the tube radio and have it rebuilt, replacing caps and out of spec resistors. It's a novelty.
Destructor is offline
CyberCholo
June 6th, 2015 04:20 PM
Mark57
April 19th, 2014 05:12 AM
HLS
February 21st, 2014 06:30 PM
HLS
February 17th, 2014 07:51 PM
68conv455
November 19th, 2011 07:36 AM
Quick Reply: 49 radio needs a replacement
