Gen light
Old May 23, 2026 | 02:05 PM
Chuxter's Avatar
1970 Cutlass Supreme
Gen light
having a little problem with the gen light on my 1970 cutlass. It just came on. I have converted over to a newer style alternator, and it wasn't on before its putting out around 14 volts checked at the battery. I don't know if it's anything that needs to be worried about. Might just pull the bulb out of gauge. Any thoughts? And be nice. lol.
Old May 23, 2026 | 02:27 PM
Which alternator did you go with? Did you install an internal reg vs an external and make the proper wiring adjustments?
Old May 23, 2026 | 03:02 PM
Chuxter's Avatar
Yes it is an internally wired alternator with the wiring harness for it . I bought the harness for that style alternator is there something I need to be looking for?
Old May 23, 2026 | 03:23 PM
What is the brand name (manufacturer) and model number of the ALT? You do not want to remove the bulb from the gauge, you want to correct the issue causing the bulb to illuminate.
Old May 23, 2026 | 04:20 PM
Texas442's Avatar
1971 442 conv
Someone please feel free to correct me, but from what I recall:
1971 Cutlass 350 was EXTERNALLY regulated
1971 442 was INTERNALLY regulated
GEN light ON means there is a Voltage differential across the bulb. Start by tracing the Pink and Brown wires
Old May 23, 2026 | 04:36 PM
Chuxter's Avatar
Yes it was originally external regulated but I have updated to an internally regulated and bought the harnesss for this regulator
Old May 23, 2026 | 05:16 PM
Texas442's Avatar
1971 442 conv
OK Thanks for the clarification. It helps if you isolate the GEN Light On to a specific Ignition Key position. Try ALL of these positions and jot down when is it ON and when is it OFF. This will help which circuit maybe suspect
Old May 23, 2026 | 07:18 PM
Chuxter's Avatar
What are the chances my board has gone bad? I have no other lights that work including the back lights. The gas gauge does work.
Old May 23, 2026 | 07:22 PM
What 'board' are you referring to? You have no other lights? No headlamps, no tail lights, no dome light, etc.? What are 'back lights'?
Old May 23, 2026 | 07:26 PM
Chuxter's Avatar
I have no other lights on that gauge.
Old May 23, 2026 | 07:44 PM
Did you check the 4A INST LPS fuse?
Old May 23, 2026 | 07:53 PM
Chuxter's Avatar
Yes. I have lights on the speedometer and the aftermarket gauges that I wired in that work with the dimmer on the headlight switch.
Old May 23, 2026 | 08:04 PM
You replaced the original (external VR) ALT w/ a newer/different (internal VR) ALT. You used an adapter wiring kit (harness) supplied w/ the newer/different (internal VR) ALT. This wiring kit was supplied w/ the newer/different (internal VR) ALT? Was there a period of time when the ALT lamp did NOT illuminate while the engine was running? You stated the ALT lamp "...just came on..." That, in itself, doesn't say much. Was there a period of time when the ALT lamp did NOT illuminate w/ the engine running w/ this newer/different ALT?
Old May 23, 2026 | 08:31 PM
You have not told us what ALT you installed in this car. Likely if you installed a 12SI ALT & the wiring to convert to a 12SI ALT was not done correctly, the GEN light will stay on. That's why both me & Eric asked what ALT you installed in Post #2 & Post #4.
Old May 23, 2026 | 08:48 PM
Chuxter's Avatar
The alternator came from auto zone remanufactured. Yes there was a period of time when the light was not coming on. I replaced the alternator after the light was staying on. The charge rate at the battery was low so I replaced it. But the light was still on. Going through it and checking wiring again tomorrow
Old May 23, 2026 | 09:46 PM
Tough to follow the course of events as described; or as I was following along.
There was a period of time when the light was not coming on w/ engine running with the older (original?) style (external VR) ALT installed I believe is what you're saying. Then, one day with the engine running the (external VR) ALT light came on. At this point perhaps (supposedly) you measured the voltage at the battery with the engine running at idle and the charge rate was low so you elected to replace the (external VR) ALT w/ the (internal VR) ALT. So, the ALT light first began to remain on while using the old (external VR) ALT. I guess you considered the original style (external VR) ALT was the issue that's why you elected to replace it, but you replaced the original (external VR) ALT w/ an internal VR ALT as you suspected the low charge rate demonstrated the ALT must be bad & this was causing the ALT light to remain on. Yet, prior to the ALT replacement the ALT light began to remain on even before the ALT replacement.
Without digging perhaps unnecessarily into any prior diagnostics/troubleshooting of the ALT or the VR you simply replaced the ALT as you suspected the ALT was bad because it demonstrated a low charge rate - this is where you are today, correct? A re-manufactured (internal VR) ALT installed in replacement of an original style (external VR) ALT w/ an illuminating ALT light & a new (internal VR) which measures 14VDC engine running @ idle. So, the original issue (ALT light remained on) occurred even before the new ALT was installed.
You need to specifically state the model number and manufacturer of the internal VR ALT and/or the style of the internal VR ALT you installed (likely either a 10SI, 12SI or CS130 alternator). The fact you purchased it @ Autozone is no help (at all). You have a receipt you can provide the manufacturer and/or model number? At the very minimum take a picture of the side and the back of the new (internal VR) ALT and post it here. There are specific types of wiring kits (harness adapters) which are germane to the type (10SI, 12SI & CS130) ALT you installed. Did Autozone provide an adapter wiring kit? Did you purchase separately a wiring adapter kit? Make your own?
Old May 23, 2026 | 09:50 PM
Does the ALT light stay on with the key inserted into the IGN SW but NOT in the START position?
Old May 24, 2026 | 12:17 PM
Chuxter's Avatar
Pulled the gauge out and had some loose pins in the circuit board. Resoldered them and problem gone. Thanks for all of the help and input.
Old May 24, 2026 | 12:23 PM
Chuck - This is absolutely amazing. In a gazillion years I would never have suspected.
I do own a 2003 Ford F-250 and many of the Ford trucks have issues with gauges which require simple reflow of solder >>> Circuit Board Medics. I removed my instrument panel, sent it in & had it back in a week.
Glad you found this issue - way to go.
Old May 24, 2026 | 01:12 PM
Chuxter's Avatar
I also suspect my bulbs. I have switched over to led which are polarity specific. I went through with an external power source and made sure they were I the correct way. After reading some of your comments and looking through my manual I realized they all share the same pin for power and the signal pin is actually a ground. Works great now. Comes on when the ignition is on and goes out when started. 1 more thing off the list.
Old May 24, 2026 | 01:14 PM
I'll say you're doing a spanking nice job of refurbishing some electrical gremlins. IIRC, you also performed an R&R of the wiring harness? Well done, sir. And, yeah, LEDs are polarity specific.
Old May 24, 2026 | 01:18 PM
Chuxter's Avatar
Garage days. Some of them can be frustrating
Old May 24, 2026 | 01:21 PM
I've never done a wiring harness R&R. For years I've maintained a stock (work bench) supply of reels of color coded wiring. I likely have replaced most wiring contained in wiring harnesses one wire at a time.
But, they're color coded to match a wiring diagram and of the correct AWG. Keep up the fine work.
Old May 24, 2026 | 01:36 PM
Noting similarities in shelving used in your garage and areas of my man-cave.
Candyman68
Jun 26, 2024 01:35 PM
berettass
May 10, 2016 09:34 AM
hookem horns
Jan 27, 2013 08:17 PM
rktw31
Apr 10, 2012 05:14 PM
Southern_Hospitality
Sep 30, 2009 02:00 PM
