Flashers
Old Sep 25, 2025 | 07:00 PM
twilightblue28A's Avatar
Flashers
Thanks to the members of CO, I have been able to repair the windshield washers, windshield wipers, convertible top switch, the horn button and the clock. Next task: the flashers. I looked on the steering column and there is no button to depress to operate the flashers. What I see appears to be a hole in the steering column. I will appreciate what I should see and the parts needed in order to return the flashers to operating condition. Will I need to remove the steering wheel? Fyi: the turn signals work correctly. Car is a '71 Cutlass Supreme convertible, automatic, floor shift.
As always, I will appreciate your help.
Old Sep 25, 2025 | 07:52 PM
Post a picture of what you are looking at. The flasher switch is built into the turn signal switch, so worst case you'll need the switch and ****. Best case, just the ****.
Old Sep 26, 2025 | 04:05 AM
Part # 398165 should be correct for all 1971 Cutlass models. Available from various suppliers.
Old Sep 27, 2025 | 03:21 PM
I took a few photographs of what I see instead of the flasher button which is missing. I hope the photographs help.
There is no button for the flashers.
Old Sep 27, 2025 | 06:33 PM
Looks like either that's the wrong turn signal switch or it is not aligned correctly. Or, the housing part of the steering column is clocked incorrectly. That hole for the **** should be at about the 4 o'clock position when looking at the column.
Old Sep 27, 2025 | 07:00 PM
Which is probably why the button is missing.
Old Sep 27, 2025 | 07:48 PM
Thank you for responding. I'll buy a switch and flasher button. What is involved in moving the housing for the steering column to the proper position? Will I need to remove the horn button , horn contact and steering wheel?
Old Sep 28, 2025 | 05:56 AM
You have to remove the steering wheel and lock plate to access the turn signal switch. Removing the lock plate requires a compressor to compress the spring so you can remove the retaining ring. Once off, the turn signal switch is accessible. I wouldn't buy any parts until I had eyes on the current switch to see what's going on.
Old Sep 28, 2025 | 06:42 AM
I'd prefer to work on anything on a vehicle other than the steering column - just a real nuisance & annoying to me, but as Joe indicated I wouldn't buy anything until you have eyes on what's going on with the turn signal switch &/or the housing of the steering column. You may have the correct switch but the housing isn't clocked correctly. Yeah, if you don't own the hazard flasher **** you're going to need one of those.
Old Oct 7, 2025 | 01:52 PM
Are the flashers and turn signals controlled by the same switch within the steering column. Thank you.
Old Oct 7, 2025 | 01:58 PM
The flashers are controlled by the turn signal switch, but it is a different set of contacts on the switch body. It's really two separate switches built into a common housing.
Old Oct 7, 2025 | 02:02 PM
Thank you. I spoke with Fusick today. I was told the switch for the flashers and turn signals is a PN # D 6208?
Old Oct 7, 2025 | 04:28 PM
I don't have the Delco crossover number, but the original GM part number is 1997963, which was used on just about every single A-body made by GM from 1969 through 1980 or so. Everyone sells these.
Old Oct 7, 2025 | 06:01 PM
https://www.fusickautomotiveproducts...p?number=D6208
Does this help?
Old Oct 7, 2025 | 06:36 PM
Not really, since it doesn't tie their part number to the GM number. If you google the 1997963 number, you will find them available for as little as $35. I'm pretty sure the one Fusick is selling is not original GM.
piperman60
Jul 23, 2020 08:44 PM
SnakeBit
Feb 22, 2016 06:52 AM
Johnfig
Nov 23, 2015 09:28 PM
Hoffman2099
Oct 2, 2015 04:11 PM
Devon76
May 30, 2008 07:57 AM
