why is one radio knob longer than the other?
Old Oct 15, 2024 | 01:32 PM
Paul Montoya's Avatar
why is one radio **** longer than the other?
I have a 1967 cutlass and took the radio out to do some work under the dash. When I took the ***** off I noticed that the right side rod where the **** pushes onto is shorter than the left side. Can anyone tell me why that is? Im trying to reinstall the radio and the back plate wont fit with the station ****
Old Oct 16, 2024 | 07:51 PM
Old Oct 17, 2024 | 05:34 AM
4R5's Avatar
4R5
That's not correct. The right side shaft (for the tuning) should be close to the same length as the left side inner shaft (volume). Does the radio work like this? Can you manually tune stations?
Old Oct 17, 2024 | 09:41 AM
yes i can manually tune stations. I pulled on the shaft but thats as far as it comes out
Old Oct 17, 2024 | 11:00 AM
4R5's Avatar
4R5
I can only guess that the shaft was pushed in, or it was replaced at some point with the wrong part. The shaft needs to be longer to allow the rear "dummy" **** behind the tuner **** or the front/rear fader that would also be behind the tuner ****. And, if I'm not mistaken, the shaft that the dummy **** or fader sits on is a larger diameter shaft, just like the tone **** on the right.
Kevin11
Aug 15, 2019 08:08 AM
jwr7042
Apr 9, 2018 07:35 PM
69442murph
May 21, 2014 05:18 AM
mat1227
Mar 28, 2014 07:03 AM
bittersweet71
May 14, 2009 04:36 AM
