Fusible Link Replacement
Old Aug 18, 2024 | 02:19 PM
Rontremayne's Avatar
What options exist to replace the fusible link in the wire from the horn relay to the fuse panel? The wire has frayed at the end of the link so I cannot repair. The more I read it appears the fusible link is a short wire that's a smaller gauge then the feed wire and there's no fuse. Is the connector nothing more then the link. Is this designed to short the smaller gauge wire?
Old Aug 18, 2024 | 02:27 PM
You can buy replacement wire at your local auto parts store.
Search for fusible link wire | O'Reilly Auto Parts (oreillyauto.com)
Old Aug 18, 2024 | 04:42 PM
cdrod's Avatar
Rodney
I bought this Pico wire on Amazon. Rule of thumb is to use a fusible like 4 wire sizes smaller than the wire to be protected; i.e. use 14awg fusible like for a 10awg wire.
Rodney
Old Aug 18, 2024 | 06:37 PM
Thanks for the feedback
Old Aug 18, 2024 | 06:40 PM
Only to assist in providing additional clarity & feedback. It's best to buy & use a wire which is "designed" as a fusible link since the core insulation & rubber insulation used when fabricating a fusible link is of different materials (which withstand greater heat and will not ignite into flame). Point is - don't just use any gauge wire unless it's designed as a fusible link.
Old Aug 18, 2024 | 06:51 PM
I appreciate the advice
tv442
Sep 23, 2022 01:04 PM
neatolds
Sep 26, 2015 08:01 PM
pcard
May 14, 2014 01:21 PM
Homestar
Oct 19, 2010 07:32 AM
ctrain22
Sep 16, 2009 05:27 AM
