1967 cutlass wiring diagram
Old May 23, 2024 | 04:32 PM
Vito 1993's Avatar
WagonWheels
Does anyone have a wiring diagram for a 1967 cutlass? I have 3v on the dead side of my "INSTU B/U " fuse... with no fuse in it. Trying to find a short. I found the pic of the 1968 wiring diagram on here but I do not know if they're the same. Thanks in advance.
Old May 23, 2024 | 05:08 PM
Vito 1993's Avatar
WagonWheels
Old May 23, 2024 | 05:23 PM
Charlie Jones's Avatar
Phantom Phixer
There's one in the 1967 Oldsmobile Chassis Service Manual.
Plus a whole lot of other information to help you fix your car.
67 1967 Oldsmobile Chassis Service Manual Original OEM ***NICE*** | eBay
I wouldn't count on the 1968 wiring diagram to be the same.
Old May 24, 2024 | 04:28 AM
jaunty75's Avatar
Here you go. If you download the image, you should be able to zoom in on it. But as noted, if you're going to work on this car at all, get an original factory service manual. There is no substitute.
Old May 24, 2024 | 04:29 AM
jaunty75's Avatar
Old May 24, 2024 | 07:33 AM
Vito 1993's Avatar
WagonWheels
Thank you guys . I ordered a manual. I was just trying to get by for the weekend. I have an old service manual with other brands in it as well but it doesn't have a schematic .
Old May 24, 2024 | 07:38 AM
As both Charlie & Jaunty indicated (above) the only manual to own for your car is the original (used) OEM CSM. At some point years ago many of us owned a Chilton &/or Haynes manual (perhaps), which included other brands, but an original OEM CSM is the bible for your car. Good on you for ordering the correct manual.
Old May 24, 2024 | 08:01 AM
jaunty75's Avatar
I have found that, while the factory service manual is a must, having the Chilton, Hanes, etc. manuals on hand as well can be helpful because they sometimes have additional figures and diagrams that are not in the factory manual as well as charts of specifications in a more compact form.
In one case, back about 15 years ago, I wanted to rebuild the carburetor on my '67 Delta 88. I didn't find any youtube videos at the time (I'm not sure I even thought to look), but I found a Rochester carburetor manual by Hanes that gave step-by-step instructions on rebuilding this particular carburetor with lots of photos. It was ten times more helpful than the factory manual ever would have been.
Old May 24, 2024 | 09:55 AM
The INST-B/U fuse feeds one side of the ALT lamp. The other side of the lamp is connected to the voltage regulator. You are reading a ground loop through the ALT bulb. This is normal. I'm not sure why you're trying to measure at that point anyway.
Old May 27, 2024 | 05:43 PM
Vito 1993's Avatar
WagonWheels
The fuse blew . And before it did. That little lightbulb for the proportioning valve/ parking brake would not shut off. Now the alt lamp is on dim. I have been out of town but I'm going to get back at it now that I have a schematic
Vito 1993
May 23, 2024 04:32 PM
joesw31
Jun 17, 2023 04:42 PM
R.D.J.
Jul 22, 2022 09:44 AM
mwbailey
Jan 22, 2022 03:20 PM
neatolds
Aug 19, 2015 11:44 AM
