1972 cutlass battery not charging
Old Nov 9, 2009 | 10:14 PM
al714's Avatar
Hi everyone your help would be truly appreciated...
lets see i've gotten a new battery, alternator and voltage regulator. but battery still not charging.Checked wires and they look ok. any suggestions cause im
Old Nov 9, 2009 | 11:40 PM
svnt442's Avatar
Have you checked the voltage at the back of the alternator and at the batter when the car is running?
Old Nov 10, 2009 | 12:08 AM
al714's Avatar
yes,i actually checked the voltage of the battery..(12.6)started the car checked it with the car on and it was the same.checked the alternator and gave same reading as the battery(12.6)
Old Nov 10, 2009 | 12:23 AM
svnt442's Avatar
I'd have the alternator retested. You could have a dud right out of the box. Also check the connections under the regulator to ensure they are clean and making good connection.
Old Nov 10, 2009 | 07:24 AM
The alternator should be putting out about 13.8 volts.
Old Nov 10, 2009 | 11:41 AM
a6m5zerosen's Avatar
1977 Cutlass Supreme
Here's a super easy 10 second alternator checkout-With the car running, take a big flatblade screwdriver and touch it to the rear bearing housing on the alternator (the round raised portion in the center of the back side of the alternator). A working alternator is an electromagnet, and there should be a reasonably strong magnetic pull at this bearing, strong enough to pull & hold the screwdriver balde to it. If there is no magnetic pull, the alternator is not charging. This test cannot tell you how ell an alternator is charging (if it is), but it can certainly tell you if it isn't.
Old Nov 10, 2009 | 04:45 PM
al714's Avatar
got the alternator checked and it came out ok..did that screwdriver test and theres no pull.you think i have to adjust the regulator??
Old Nov 10, 2009 | 05:31 PM
If there is no pull, the alternator is not charging. I assume this is an externally regulated alternator with a voltage regulator mounted to the left inner fender? Did they put it on a test stand and run it with a belt driven by an electric motor? I would remove the alternator, take it back to the parts store, & have them test it again, & try the pull test while they're doing it. If there is no pull, have them check another one from stock & do the pull test.
The magnetic pull is a law of physics-if it is charging & generating an electric current, there will be a magnetic pull at the rear bearing of the alternator. Try it on another car if you have one & you'll see what I mean-just be careful, of course, not to ground the electrical post with the wires on it on the back of the alternator (most have a rubber nipple or plastic cap covering it, or at least they did when new). If the alternator tests good on the test stand, verify the wiring is good to the regulator, & that there is no corrosion or excessive dirt at the connections to the regulator. Is there a separate ground wire going to the regulator? If so, make sure it is clean & tight at both ends. Also, have you checked for voltage at the big wire going to the post on the rear of the alternator from the battery? If is is not there, or is low, check this wire carefully-feel it with your fingers along as much of its length as you can. If you feel a "kink" or a soft, mushy, or crusty feeling spot, this could be contributing to your problem-I've seen these wires corrode inside the insulation. Once you get your alternator charging, here's another super simple 10 second electrical diagnostic check that anyone can do. At night, with the engine running & the lights on, connect a good pair of jumper cables from a good ground on the engine to a good grounding point on the firewall or chassis. Did anything change? Did the dash lights get brighter? if they did, then the engine to firewall ground strap is either broken, corroded, loose, has corroded terminals, or is missing altogether (I see this one ALL the time, usually as a result of an engine or trans swap). New straps are cheap & readily available in the "help" section of any good parts store, usually in a red cardboard blister package.
Old Nov 10, 2009 | 06:02 PM
Quick question-is your new voltage regulator a mechanical regulator, as original, or one of the new solid state (electronic) ones?
Old Nov 10, 2009 | 08:34 PM
al714's Avatar
i want to say mechanical..the box is kind of big
Old Nov 10, 2009 | 08:57 PM
The voltage regulator will be externally the same size whether it is mechanical or solid state. Does it have a removable cover? If so, remove it &
look underneath-if it is a mechanical type there will be a setup very similar to a points-style ignition that opens & closes-that is what regulates the voltage. Caution-disconnect the battery before removing this cover-it is easy to accidentally ground out the regulator. If it is a solid state type, there will be a circuit board with transistors on it. If you have a choice, the solid state is a much more reliable, trouble free unit with no moving parts & no contact points to wear out.
Old Nov 10, 2009 | 09:18 PM
al714's Avatar
something i noticed today was that the last owner has the alternator ground connecting to aftermarket gauges (temp,oil,amp).i put an extra ground from alternator ground to chassis just in case but nothing..the regulator has a metal braided strip from one screw going to the engine thats ground, right? one more thing i can think of doing is getting new regulator connector wires.ones i have are old and might be corroded.also before i changed the regulator the gen light would light up when car was on not to bright.when installed new regulator light can only be seen at night thats how dim it is.
Old Nov 11, 2009 | 06:38 AM
stellar's Avatar
stellar
Look for blown fuse maybe marked (gauges) sounds like an open circuit on brown wire.
Old Nov 11, 2009 | 09:10 AM
I believe you may have multiple issues. Do you have a factory (not an auto parts store manual diagram) color coded wire diagram for this car? If not, perhaps someone on this forum can scan the relevant sections & email it to you, or post on the forum. Once you have this, check the wire colors & connectors. Payspecial attention to anything that looks altered or non-stock-look for cheap auto parts store splices or scotch-locks (blue plastic rectangular foldover splices), wires twisted together & taped, etc. Lots of time you see this under the dash (as a result of a bad stero install), near the fuse box (as a result of a bad accessory installation-guages, lights, etc), in the trunk (as a result of a bad trailer light or speaker wiring attempt), & under the hood (lots of reasons-hooking up aftermarket guages, tach, ignition upgrades, fog lights, etc. Check out that alternator again, too-I think you've got a bad unit. Take it to a different store, or have it checked by a different employee.
Old Nov 11, 2009 | 10:32 AM
OLDSRALLYE350's Avatar
Does the red alternator light on the dash work ? Should be on with the key in run position and the motor not running.
Old Nov 11, 2009 | 08:58 PM
al714's Avatar
im going to take alternator to another shop to get tested just in case.and i got myself a factory electrical diagram.going check all wires to make sure there not altered or damaged...yeah the red light works with key in run position.
Old Nov 15, 2009 | 04:48 PM
al714's Avatar
finally worked... it was the blue cable coming from the alternator that was pinched i cut it and put a new wire and it started charging without a problem....Thanks to everybody who helped.
Old Nov 19, 2009 | 09:04 PM
Now that it's working, do the pull test on the back with a screwdriver, so you'll know what it should feel like next time...
Rocketowner
Jul 1, 2015 07:16 AM
WendellB
May 24, 2015 08:48 AM
FlyingV5150
Oct 6, 2014 04:31 PM
76olds
Mar 3, 2014 03:31 AM
jtriggy
Jul 17, 2010 12:33 PM
