Rally Pac Oil Sending Unit
Old Jun 5, 2023 | 06:43 AM
tnswt's Avatar
'70 4-Speed W Machine
Is there an effective method for testing the functionality of an OEM oil sending unit when not on the car?
I've located a seller that has a black, OEM 6462137 with a good date for my '70 442. The seller has no car to test the unit, but performed a multimeter test on the unit and states it shows as working. There is no oil leaking from around the base of the unit. I did not ask but considering the exterior condition I believe it has been on a shelf for a while--not on an engine.
Considering this unit is quite pricey, is an old electrical part, and I want the part to install on my car, is there a better test, short of installing on an engine to determine functionality, or is the multimeter test effective?
Thanks for your response.
Old Jun 5, 2023 | 10:16 AM
Unless you can apply variable pressure, any testing with a meter is just continuity. It won't tell you if the unit actually works when pressure is applied or if it is even close to accurate.
Old Jun 5, 2023 | 11:48 AM
stlbluesbrother's Avatar
From my understanding Redline Gauge Works in California has a service in which they can test and calibrate a rally pack oil pressure gauge to a sending unit. You'd need to ship both components. I've never used this service, but it's an option if you have time and money.
Old Jun 5, 2023 | 12:24 PM
A tee fitting on any running engine and an ohmmeter will do the same thing. Use a mechanical gauge as a pressure reference. Three data points should be sufficient as the potentiometer should be linear.
ChillyJ
Sep 3, 2020 03:18 PM
yalikeme
Sep 4, 2015 12:25 PM
69442murph
Jul 14, 2014 10:52 AM
stevengerard
Oct 30, 2010 07:53 AM
boese1978
Jan 22, 2008 11:56 AM
