6 volt systems
Old Mar 6, 2023 | 09:42 AM
edzolz's Avatar
6 volt systems
Those of us that have cars with 6 volt systems, I have a question. If the battery maintains 6.2 volts, is that enough to start the car. I only has about 6:1 compression. But before I buy a new battery (mine drops to 6.2, even after charging to 7.1) is that OK? Haven't tried to start the car yet with the 6.2 volts.
Old Mar 6, 2023 | 10:03 AM
rocketraider's Avatar
Oldsdruid
Ed, as long as your starter and charging system are in good repair, and you have properly sized battery cables (0 or 2/0 minimum) you shouldn't have any issues starting. Make sure all connections are clean too.
Old Mar 6, 2023 | 10:17 AM
Your battery is probably on it's last leg.
bronze66f85
Dec 20, 2021 09:26 AM
tru-blue 442
Oct 17, 2020 04:58 AM
mishcar
Aug 10, 2015 06:41 PM
Glens 62
Jul 16, 2014 03:20 PM
hmartin
Mar 7, 2013 05:12 AM
