Is this correct for a 70 442 w-30 4 spd?
Old Nov 29, 2021 | 10:54 AM
scrappie's Avatar
I cant get confirmation but wanted to know if anyone has experience with this? Is this the same for a 4 spd W30?
https://www.ebay.com/itm/39002045596...pid=1461660614
Old Nov 29, 2021 | 01:25 PM
69 Hurst's Avatar
Olds Fanatic
Fusick has the correct cable...
Positive Battery Cable, 1970 350 V8 with A/T, 4V, 455 V8 Positive battery cable for 1970 Cutlass with 350 V8 engine, automatic transmission and 4 barrel carburetor, and all Cutlass and 442 models with 455 V8 engines. Cable has spring ring terminal as original.
http://www.fusickautomotiveproducts....?number=P14580
Old Nov 29, 2021 | 01:51 PM
My442's Avatar
I would look at M&H as well.
The 4 speed cable is longer than the A/T cable due to routing.
Old Nov 29, 2021 | 02:20 PM
joesw31's Avatar
I used cables from Fusick and they are very accurate. They also have the correct part number on them per application and are not generic
Old Nov 29, 2021 | 03:33 PM
scrappie's Avatar
This is what throws me off because it doesn't say anything about manual trans just automatic. Routing for the manual car is much different than auto. It then says "all 442 models"
Old Nov 29, 2021 | 04:55 PM
joesw31's Avatar
The assembly manual has it as 8901058 code GN. One number for all 455s
TRFREE
Jul 31, 2025 06:12 AM
Vader
Nov 6, 2018 10:39 AM
Vader
Jun 9, 2014 08:07 AM
droptopcad
Cars Wanted
Oct 12, 2010 07:19 AM
1badw30
Sep 12, 2007 05:36 PM
