Alternator
Old Nov 29, 2021 | 10:22 AM
ART T's Avatar
Alternator
I am looking for a high output, oem, alternator that I can adapt to my 330. Any suggestions? Making brackets is not a problem.
Old Nov 29, 2021 | 10:31 AM
66SportCoupe's Avatar
There is a company on eBay offering a stock looking and mounting 135 amp alternator for gm vehicles. $110 plus shipping. Have one on my 66 442 drag/street car. Works amazing. Must use a solid state voltage regulator.
Old Nov 29, 2021 | 10:44 AM
What do you consider "high output"? Is there a reason why you think you need more than 95 or 105A? There are two really easy, relatively inexpensive options. Any 12SI bolts to your existing brackets. You can get a 94A 12SI for a 1986-87 Caddy Fleetwood with the Olds 307. This is an internally regulated unit. RockAuto has them in the $75-90 range, depending on vendor. You can also get a 105A CS130 for a 1989-90 Olds Custom Cruiser with 307. This also bolts to your existing brackets with no mods. The CS130 requires only slightly more wiring mods than the 12SI. This one is about $80-105 from RockAuto.
Old Nov 29, 2021 | 11:25 AM
ART T's Avatar
I had an Oldsmobile file on my old laptop and I am trying to reconstruct it. I like the look of the small housing, internal fan, alternators. Thanks for the info.
Old Nov 29, 2021 | 10:16 PM
cjsdad's Avatar
CS130 from Amazon is $78 and change brand new. It was a bolt-in upgrade on my 67. Just add a different plug that fits it and make a couple jumpers to bypass the external regulator, do a search in the electrical forum for Joe P's instructions. On mine, I did have to rotate the rear housing 90° so the output post would clear the valve cover, YMMV.
Old Nov 29, 2021 | 10:42 PM
Really no rewiring or anything. Just have a updated voltage regulator. No wiring mods.
https://www.ebay.com/itm/263211754586
Old Nov 30, 2021 | 04:27 AM
66luvr's Avatar
I used this on the blue car.
Alternator Conversion Kit Delco 10DN External Regulator to 10SI 12SI Internal | eBay
I just removed the regulator and slid the wiring behind the harness, can't notice it.
Old Nov 30, 2021 | 05:50 AM
I used the same alternator on my 62 F85. No issues at all for the last 11 years.
Old Dec 9, 2021 | 07:58 AM
ART T's Avatar
Thanks. I like the caraige bolt.
Old Dec 9, 2021 | 07:59 AM
ART T's Avatar
Old Dec 10, 2021 | 08:38 PM
cjsdad's Avatar
The square shoulder rides in the adjustment groove nicely so only one wrench is needed for loosening or tightening. It was kinda an accident that I found out how nicely it works. It was a temporary bolt to hold the alternator in place but it looked nice enough, I left it.
Old Dec 11, 2021 | 06:57 AM
The only problem with the hardware store carriage bolt is the Grade Zero metal quality. Don't overtighten and inspect periodically for fatigue cracks. Those bolts are pretty much made of crap.
OLDsBARRY
Oct 20, 2021 02:34 PM
Skydog9
Jan 8, 2021 10:01 PM
capstoneclub
May 4, 2013 08:39 PM
my442conv
Sep 15, 2011 07:55 AM
442b
Sep 1, 2011 12:00 PM
