Engine wire harness
Old Apr 10, 2021 | 05:51 PM
Puppy boy's Avatar
Engine wire harness
Engine wire harness1970 442 auto,about 4 inches from the coil I have two green wires that branch off to a black plug this is about 14 inches long.There is some kind of a resistor that someone has installed in the back of the plug but i don't know why or what its for.I have checked the wiring diagrams but can't see them good enough.
Thanks in advance Rick
Old Apr 10, 2021 | 06:21 PM
The plug into the solenoid for the transmission controlled spark system.
Old Apr 10, 2021 | 09:21 PM
Puppy boy's Avatar
I have the three ports right by the oil fill tube with no electrical connection .other posts indicate this may be a 71 ,72 thing.would my harness have the wires and plug that were not used,and why would some one have installed a resistor in the harness plug.Thanks All
Old Apr 11, 2021 | 05:21 AM
Go back and look at the drawing that I posted. The 1970 solenoid does not screw into a coolant port, it bolts to a bracket. That plug connects to the two terminals on the solenoid. This is what the 1970 TCS solenoid looks like.
Old Apr 11, 2021 | 06:44 AM
The resister is there for back EMF suppression. It dissipates the current load when the circuit is turned off.
Old Apr 11, 2021 | 07:05 AM
Puppy boy's Avatar
Very good info, but not done yet.Joe your drawing says except AC,I have AC, Should the 3 port behind the oil fill tube be removed with the solenoid installed.And are the available ,the one in the picture looks very shiny.
Thanks again
Old Apr 11, 2021 | 11:54 AM
Thanks again
That was the first drawing I grabbed. Given that you didn't tell us the car has A/C, the mind reading thing still isn't working.
The fact remains that the two wire connector plugs into the solenoid valve that I posted. Feel free to crack open your 1970 Chassis Service Manual and do your own research on vacuum line routing. The 1970 system used separate solenoid valve and thermal valve. The 1971-72 cars integrated the two into a single unit that screwed into the coolant port and had the solenoid built into the top.
Old Apr 11, 2021 | 05:35 PM
Puppy boy's Avatar
Sorry about not including all of the pertinate information .I'm new to the forum ,and didn't me to stress you out,maybe you should take a few days off.
I guess if every body had a service manual we would need such a forum.
Rick
Old Apr 11, 2021 | 09:35 PM
Rick
I wouldn't bite the hands that feeds you information.
Old Apr 12, 2021 | 08:54 AM
rocketraider's Avatar
Oldsdruid
Puppy, if you don't have a factory 1970 shop manual it needs to be on your list. There's amazing stuff in them and will help you and anyone else understand and service your 70. Gotta remember things have changed after 50 years and finding people who worked on these cars back in the day ain't easy.
But yeah, the resistor is factory, to reduce radio noise. Oldsmobile used windshield antennas starting 1970 and they were doing all kinds of weird things to eliminate radio noise and static. Would have been simpler to have stuck with a mast antenna...
Old Apr 12, 2021 | 08:58 AM
The resistor has nothing to do with noise. The factory used filter capacitors on electrical items that generated noise,
Old Apr 12, 2021 | 09:16 AM
Oldsdruid
Look in your 1970 Service Guilds and TSBs.
Old Apr 12, 2021 | 12:03 PM
Puppy boy's Avatar
Thanks Rocket i will be ordering a service manual.Just picked up the car so i haven't made my first part order yet.
Old Apr 12, 2021 | 01:33 PM
Oldsdruid
Get an original 1970 printing if you can. You might pay more but it's a better quality book than the reprints. Reprints lose detail especially on the color wiring diagrams.
A Fisher Body manual helps too along with any other factory issues service literature.
A Motor's or Chilton's Professional Trades Edition general service manual that covers your year is often helpful on troubleshooting and unit repair. Has to be the PTE. Those are what a general repair garage would have used.
We'll help you any way we can because we've all been there. But the internet doesn't have all the answers and depending on the source is often just flat wrong. Hopefully you haven't found the OldsFAQ yet. Joe P and others have been trying to correct its many inaccuracies but that's like Sisyphus rolling his stone uphill.
Old Apr 12, 2021 | 06:19 PM
Puppy boy's Avatar
Thanks for the good info on the service manual.
Old Apr 14, 2021 | 05:50 PM
Cutlass Fan's Avatar
Rick
Oh yes we would! It is invaluable but doesn't answer all questions.
does the resistor connect to the coil? If so the resistance wire may have failed and been replaced with a Chrysler style resister. I did that on my 72 back in the day.
Old Apr 14, 2021 | 07:58 PM
Has nothing to do with this thread or conversation, totally different subject.
oldsmoboogie
Mar 12, 2021 02:55 PM
Microreedy
Jul 19, 2016 08:21 PM
1968_Post
Nov 9, 2014 05:33 AM
Beob
Mar 5, 2011 01:45 PM
