Wipers not working
Old Sep 20, 2020 | 08:42 AM
abody's Avatar
Wipers not working
My 70 Cutlass was in a shop for a while, I had a new ignition switch put in, ignition works fine but I just realized it doesn’t go to the back position. Would this have anything to do with the wiper motor not working? It looks like the original motor and was slow the last time I used it
Old Sep 20, 2020 | 09:18 AM
No, that has nothing to do with the wiper motor.
Old Sep 20, 2020 | 09:26 AM
First you need to determine if you have power and the ground triggers from the wiper switch. If both are present then your issue is related internally to the motor itself.
Old Sep 20, 2020 | 09:41 AM
To clarify, the wiper switch does not provide power to the wiper motor - only ground. The power comes from the yellow wire that plugs into the motor - this wire is hot at all times with the key in the RUN position.
Old Sep 20, 2020 | 11:33 AM
abody's Avatar
Thanks, seems like the yellow was loose, I put a tester on it and they started working
Old Sep 20, 2020 | 01:55 PM
Well that was easy.
Old Sep 20, 2020 | 02:02 PM
Well that was easy.
It's even easier if you open the CSM BEFORE the laptop...
SnakeBit
Jul 16, 2016 09:21 AM
olds 307 and 403
Apr 10, 2016 05:52 PM
atkinsom
Oct 16, 2014 07:07 PM
razor07
Ninety-Eight
Mar 18, 2014 12:50 PM
woodie582
Sep 16, 2008 09:00 AM
