Turn signal switch and steering column
Old Aug 17, 2019 | 10:15 AM
Philfinley's Avatar
Hi everybody
I just joined and This I s my first post...I’m attempting to replace my turn
signal switch on my 67 Olds 442. I have got as far as removing the wheel and the old switch but now I’m stuck! My question is how do I get the steering column over off?
in the picture there is kind of a plate on the column shaft that seems to rotate a little but I can’t figure out whether it un-screws? Or just pulls off?
then and need to figure out how to get the new wiring harness run down inside the column cover? Or could I cut and splice?
any help or advice would be very much appreciated
Old Aug 17, 2019 | 10:33 AM
PatL's Avatar
why do you want to take the column off if you are replacing the turn signal switch ? on a 71, the turn signal harness runs done inside the column in a sleeve and you unplug it at the bottom of the column. Perhaps the same with yours ?
Old Aug 17, 2019 | 11:04 AM
Philfinley's Avatar
Hey thanks for getting back to me. I don’t want to remove the column, just the cover. There is no way I can pull the wiring thru as it is, even if I disconnect the Connector under the dash
Old Aug 17, 2019 | 11:22 AM
PatL's Avatar
is there a c ring or snap ring that is holding that plate on ?.
I have done all of this on a 71, so don't want to misguide you, but is probably similar.
Do you have a chassis manual for your car ?.
That and the assembly manual were the best investments I made and extremely helpful.
Old Aug 17, 2019 | 11:53 AM
Philfinley's Avatar
Could be I’ll check, yes an assembly and chassis manual is going to be my next investment
thanks for your help
Old Aug 17, 2019 | 04:51 PM
72455's Avatar
1972 U code Supreme
You Tube and Google are your best friends...trust me😀
Old Aug 17, 2019 | 05:16 PM
Philfinley's Avatar
i got it..,nit the easiest thing to do but I have a function turn signal switch and I got the wiring harness down the column by loosening the lower mounting bracket.,,,
Old Aug 17, 2019 | 07:52 PM
72455's Avatar
1972 U code Supreme
Originally Posted by Philfinley
Ding ding ding! You win! And did you use string or wire to pull the new one back down through the column?
bobbyshaw
Oct 22, 2016 06:13 AM
Stephen0523
Sep 21, 2016 09:12 AM
justinj
Feb 2, 2014 05:32 PM
elcaminodave
Sep 12, 2008 07:01 AM
projectheaven
Aug 17, 2008 08:58 PM
