Turn signals
Old Aug 14, 2008 | 08:07 PM
projectheaven's Avatar
Turn signals
Hello all,
I just had a problem happen today.I was driving and all of a sudden a buzzer went off in my car.When I made it home I figured out that my turn signals werent working.I tried to replace the fuse and it worked for about 3 seconds and blew.Does anybody have any idea what might be going on?
Old Aug 15, 2008 | 04:12 AM
rocketraider's Avatar
Oldsdruid
Sounds like the key warning buzzer wiring has shorted against one of the t/s wires down in the column. Requires partial disassembly of the column to fix it. You'll have to pul the t/s switch and wiring far enough out of the column to find the short and repair.
I think the buzzer lead is the pink wire in the column harness. You should be able to see it in the harmonica connector at bottom of column.
Worst case is you'll need a new t/s switch. Not a difficult repair and it can be done with column in car.
Old Aug 17, 2008 | 08:58 PM
I found the problem.Another one of my fuses was blown causing the turn signal not to work.It was one of the aux fuses. Weird!!!!!! At least the problem is taken care of now.
thanks for the help
palmers65
May 30, 2008 11:12 AM
cola
Mar 21, 2008 03:44 PM
h4l420
Ninety-Eight
Jan 31, 2008 10:30 PM
wizzy01
Nov 20, 2007 04:03 AM
falconsfan
Mar 19, 2007 04:58 PM
