70 voltage regulator vibrates and whines
Old July 22nd, 2018, 07:39 AM
top down's Avatar
hello all,
I have a 1970 Cutlass Supreme convertible - my external voltage regulator whines (pitch changes with engine rev), the GEN light is on, and the regulator feels like it it is vibrating when I put my hand on it. Replaced the regulator with a NAPA regulator - same problem continues - took the alternator in for a check - checked as OK. What the heck it up?
Owned the car for 20 years, never had electrical problems before...
Original alternator # 1100777 55 Amp OA27 - car has AC & 350 engine, if that matters.
Help me figure out what is wrong...
Thanks!
Scott in PA
top down is offline
Old July 22nd, 2018, 07:52 AM
stellar's Avatar
check grounds. If you have a condenser on the reg, unplug it to see if vibration quits. Try a solid state reg on it from a parts store. They look like the same but are lighter and have no points in them. Usually cheaper too.
stellar is offline
Old July 22nd, 2018, 08:22 AM
top down's Avatar
what grounds to check?
I have checked the battery to engine block grounding wire, and the regulator is secured screwed to firewall, so what other grounds should I be checking - Had the car for 20 years, and never had ANY electrical problems before (lucky, I know) - so I am new to trouble-shooting this kind of problem
Also not the condenser - already checked that...
top down is offline
Old July 22nd, 2018, 08:34 AM
stellar's Avatar
Check body ground, or run a temporary jumper from bat to reg base to test. Check for corroded wires at reg plug.
stellar is offline
Old July 22nd, 2018, 10:18 AM
top down's Avatar
going to buy solid state relay now
checked all the grounds with volt meter, continuity check - all good, contacts clean. Going to buy a solid state relay now (auto zone). let you know how it goes...
thanks
top down is offline
Old July 22nd, 2018, 12:51 PM
top down's Avatar
fixed
So a $21 part from Auto Zone # VR715 - solid state voltage regulator - fixed the problem. Plugged right in, drove it for 30 minutes - no issues.
The standard voltage regulators from NAPA Echlin part # VR142 (tried two different ones) at $71 were causing the problems.
Stellar - Thanks for the advice
Scott
top down is offline
niko000
August 11th, 2017 12:48 PM
Chris J
September 14th, 2014 04:07 PM
delta_88_germany
February 22nd, 2014 01:48 PM
Texas442
March 31st, 2011 12:33 PM
D Appeldorn
December 21st, 2009 02:12 AM
Quick Reply: 70 voltage regulator vibrates and whines
