Charging
Old July 13th, 2018, 07:59 PM
big man's Avatar
Charging
I'm sure this question has been asked a few times but I'm curious as to why my voltage isn't healthy?
What I've noticed is on my sniper, and also dash gauge, I'm only getting around 11.8 volts running. I thought I just needed a battery so I replaced it with a new one..still no luck? I have noticed before that my voltage actually seemed really high, like 18 or so and this was before the sniper so I thought my gauge was just acting weird but nonetheless it must of been telling the truth. Any suggestions on what to test before I start to throw parts at it? Thanks
big man is offline
Old July 14th, 2018, 03:34 AM
You need to get your alternator and voltage regulator tested. Running voltage should be 14.5ish, engine off battery voltage should be around 12.6ish.
oldcutlass is online now
Old July 14th, 2018, 03:46 AM
stellar's Avatar
whats a sniper?
stellar is offline
Old July 14th, 2018, 03:55 AM
Originally Posted by stellar
whats a sniper?
Fuel injection.
Old July 14th, 2018, 04:01 AM
stellar's Avatar
thanks sorry for my ignorance
stellar is offline
Old July 14th, 2018, 06:36 AM
Tedd Thompson's Avatar
I wish I had your ignorance, I'd be a smart man..... Tedd
Tedd Thompson is offline
Old July 14th, 2018, 08:03 AM
stellar's Avatar
Thanks Tedd. It looks like I fooled you.
stellar is offline
Old July 14th, 2018, 09:51 AM
big man's Avatar
ok how do you test the voltage regulator? Do you put your test leads on it the same way you'd see if the alternator is charging at the battery?
big man is offline
Old July 14th, 2018, 06:24 PM
I would suggest replaceing the old school externally regulator with a newer.internally regulated regulator. Go to the parts store, ask for a alternator for a Toronado, that should be 78 or 94 amp alternator, witch will be plenty for your car. You will need to upgrade the charge wire, and make some very minor wiring changes. I wish I knew how to post pictures, I’d post a diagram.
matt69olds is offline
Old July 15th, 2018, 05:33 AM
stellar's Avatar
To test or condemn the regulator on the car, you will 1st need to test the wiring and the alternator. If you have an external regulator test the wiring like this. Looking down on the reg there will be 4 wires. Left to right the reg will be marked (F 2 3 4). Unplug wires from regulator and alternator. With key on in run position, test for voltage at the alternator battery post and at the regulator plug test for voltage at wire 3 and 4. All three should be hot with key on. Now test for continuity on wires F and 2 from regulator plug to alternator plug. If these all test good and you have a good ground on the regulator, let us know and we can move on the testing the alternator with the regulator out of the circuit.
stellar is offline
pettrix
September 21st, 2018 02:53 AM
Mike70GoldOlds
April 23rd, 2015 12:58 PM
dom992
August 7th, 2014 11:26 AM
Tedd Thompson
September 27th, 2010 12:29 PM
71 Cutlass
August 22nd, 2010 11:44 AM
Quick Reply: Charging
