66-67 Circuit board pin repair (who has fixed these and how)
Old May 18th, 2018, 06:53 PM
lemoldsnut's Avatar
66-67 Dash main circuit board plug in pins are common to break. Who has come up with a suitable repair for these? Ideally a pin replacement procedure.
I will post a picture to make it clear what I am talking about.
Larry
lemoldsnut is offline
Old May 18th, 2018, 07:22 PM
2blu442's Avatar
Larry, Randy C. found a method that worked. Here's an old thread where he described it.
https://classicoldsmobile.com/forums...uit-board.html
2blu442 is offline
Old May 18th, 2018, 07:28 PM
lemoldsnut's Avatar
Thanks John that is great if you have the pins and will work well.
Now if I do not have the pins. I wonder if anyone else has come up with a place to get the pins?
Old May 18th, 2018, 09:26 PM
RandyS's Avatar
I don't know of any resource for the pins, except maybe Ron Roth. That being said, I count 10 pins on that board. There are several brands of connectors, Molex being one of the primary ones, that make 10 circuit connectors. You could solder wires on to the circuit board where the pins mount, and to either the male or female Molex connector pins. (Connectors & Pins are purchased separately).
Cut the round plug off of the other end, and solder those wires to the mating Molex connector pins. Keeping the proper orientation of the wires will be the most difficult part of the job. The two halves (male & female) snap together and won't come apart unless you want them to. Just a thought.
Here is an example link from Mouser Electronics, they carry a full line of Molex as well as other brands of connectors.
https://www.mouser.com/Search/Refine...rd=170001-0110
RandyS is offline
Old May 19th, 2018, 03:39 AM
Here is another way of doing it.
oldcutlass is online now
Old May 19th, 2018, 04:06 PM
rroth01's Avatar
Location: Orion Township Michigan 30 Miles North of the Murder City
I must have 60 Circuit Boards that are in Perfect Shape.
rroth01 is offline
White_Knuckles
August 5th, 2014 04:23 PM
Flye
August 11th, 2011 01:21 PM
bobfo1
July 23rd, 2011 05:59 PM
yugsdlo88
April 20th, 2011 05:58 PM
KQQLCAT
November 12th, 2008 07:31 AM
Quick Reply: 66-67 Circuit board pin repair (who has fixed these and how)
