Ignition problems
Old April 21st, 2018, 04:04 PM
Ronnie1972cutlass s's Avatar
Ignition problems
I have a 1972 cutlass s with 350 2 barrel and 350 transmission. I replaced the points with pertronix 2 and matching coil. It started great for a short time. But I also had it wired with the resistor wire. Has cut off and the last time I drove it had to be towed home. Since then I found the black wire from module have grounded out. Fixed that car started great but died 20 minutes later. Also ran new wire from ignition terminal from fuse box. And it ran for about 45 minutes and I thought problems was solved. But went out this morning and it went hot a lick for nothing. Any ideas?
Ronnie1972cutlass s is offline
Old April 21st, 2018, 05:44 PM
W30
truckman5000's Avatar
idk
always start at square 1..
I'd say after that replace ignition. I have the crane cams, one...never gave an issue
truckman5000 is offline
Old April 21st, 2018, 06:00 PM
Ignition
You say replace ignition with what exactly? Coil? Pertronix module? Switch?
Old April 21st, 2018, 06:04 PM
Ignition
I have it wired to 12v from the fuse block. It has the proper voltage thinking either the pertronix module or coil gave up.
Old April 21st, 2018, 06:11 PM
W30
Yah so seems like you started at giving power, and it's no spark. So I'd say it's the pertonox. Pertonox, is a common brand of a points electronic conversion. I have crane cams version.
Old April 21st, 2018, 06:13 PM
W30
Could be anything, you have a spark checker, there cheap.
Old April 21st, 2018, 06:43 PM
I moved your post and responses to a new thread, no reason to resurrect an old one that was about a points system. Is your Pertronix II wired by figure 2 or 3, note the yours has a resistor wire in place of the ballast resistor? Have you made sure you have 12v at the coil plus terminal in both the start and run key positions?
oldcutlass is offline
Old April 21st, 2018, 07:35 PM
Ignition
By 3 I guess. It does have 12+ volts when switched on and running. Do I need to remove the resistor wire even though I ran a new wire from ignition terminal from fuse panel?
Old April 21st, 2018, 07:44 PM
So you have the original resistance wire connected to the coil pos post and the red wire from the Pertronix connected to the wire you ran from the IGN terminal in the fuse box?
Or do you have the original resistance wire, the wire from the IGN terminal in the fuse box, and the red wire from the Pertronix all connected to the coil pos terminal?
Old April 21st, 2018, 08:09 PM
Yes
Old April 21st, 2018, 08:10 PM
Yes to the last scenario
Old April 22nd, 2018, 05:59 AM
Remove the resistance wire and the red wire from the coil. Tape the end of the resistance wire and connect a 12ga jumper wire direct from the battery (pos) to the red wire. Try and start the engine. If it runs fine, you had a low power situation and need to check your connections or find a different key on source. If you connect a test light to the neg side of the coil it should blink while cranking to show that the sensor is actually sending a ground pulse to the coil to fire.
Note in order to shut the engine off you must disconnect the jumper from the battery.
If it still won't start, is wired correctly, and you have around a .030 gap between the magnet and the pickup, the Pertronix is bad.
Old April 22nd, 2018, 01:26 PM
Ok I will do that when I get home. Will post results. Thank you for your response.
Old April 22nd, 2018, 06:31 PM
Ok I did what you said and still no start. I have a new pertronix module and coil coming this week. Hope this fixes it . I'd like to drive it again. Kinda miss it.
Old April 22nd, 2018, 06:41 PM
I was just thinking, you need to connect the red wire and the battery jumper to the coil+ terminal and then crank it over. What I told you to do above left no connection to the coil, right?
Old April 23rd, 2018, 04:59 AM
No it still had the wire from starter and the one I ran previously from fuse box.
Old April 23rd, 2018, 05:19 AM
Ok, its probably the Pertronix. Let us know how it works out with the new one.
Old April 23rd, 2018, 06:31 AM
Ok will do. Thank you
Old April 23rd, 2018, 10:39 AM
TripDeuces's Avatar
I had a problem with a Pertronix unit when I worked in a shop back in the day. I called Pertronix and they gave me a simple test to perform but for the life of me I can't remember the procedure. They are very helpful on the phone and will help you right out, give them a call.
TripDeuces is offline
Old April 23rd, 2018, 04:35 PM
Ok I'll try that. Thank you for your response
Old April 23rd, 2018, 08:01 PM
Tedd Thompson's Avatar
Not uncommon for a Pretronixs to take a module dump on you at the most opportune time. Some run forever some not so much.... Tedd
Tedd Thompson is offline
Old April 23rd, 2018, 08:43 PM
Proud Viet Nam Veteran
redoldsman's Avatar
As Tedd may remember, I used to be a big proponent of Pertronix and he was a big proponent of points. When the Pertronix is working it is maintenance free. I had the Pertronix in my 54 leave me on the side of the road last year. I went back to points and keep points, condenser, rotor and cap in the trunk. I am now in the Tedd camp. You will not see any increase in power on the basic Pertronix.
redoldsman is offline
Old April 24th, 2018, 05:20 AM
If you are wired like picture 3 above, you can still run the Pertronix and keep a set of points and condenser in the car if it fails. All you need to do is pull the magnet of the shaft, remove the sensor and, install/set the points and condenser using the sensor black wire to coil-.
Old April 24th, 2018, 06:17 AM
That is what I plan to do once I get the new stuff. Yall are a big help. I've done these swaps before with no issues. But as soon as the new parts come in I'll post an update. And in the meantime I am going to get new points and coil and set them for use in case of failure of the pertronix again.
Old April 26th, 2018, 08:18 PM
You shouldn't have to keep a extra coil on hand (unless you are afraid of your old coil could given it up) as points will run just fine on the Pertronix coil or vice a versa. You will need a condenser as mentioned above... Tedd
Old April 27th, 2018, 04:41 AM
I thought since it was the flame thrower 2 coil the resistence would be different and the points would need a different coil.
Old April 27th, 2018, 08:19 AM
You would need to re attach the ballast resistor if you haven't removed it if using points but the Flame Thrower though it has a catchy label will run point just fine.... Tedd
Old April 27th, 2018, 08:25 AM
Ok thank you for your help. Good to know all I would need to keep with me is the points and condenser.
Old April 27th, 2018, 08:35 AM
redoldsman's Avatar
One trick on the resistor is putting both leads on the same terminal on the resistor. That way you can put it back in use real easy if you need to go back to points. The other benefit is most people would never notice both leads are on the same terminal so it still looks stock.
Old April 27th, 2018, 10:41 AM
So can I leave the resistor hooked up with the new wire from fusebox?
Old April 27th, 2018, 11:01 AM
  #31
Do you have a resistor or a resistance wire?
Old April 27th, 2018, 01:39 PM
  #32
Resistance wire.
Old April 27th, 2018, 02:56 PM
  #33
redoldsman's Avatar
My apologies about connecting the wires on the resistor. That would work on mine and Tedd's car where we have a resistor. I knew the 72 had a resistor wire and just was not thinking.
Old April 27th, 2018, 03:08 PM
  #34
After a bit of research, the recommended method using the Pertronix II with a Blaster II coil is not to use the resistance wire. So tape the ends of the resistance wire and the bypass wire from the starter, and stow them away. Run a 12ga wire from the IGN terminal in the fuse box to the coil + terminal with the red wire from the Pertronix II module. Connect the black Pertronix II module wire to the negative side of the coil. Basically you are wired as per figure 2 above. You should have 12v on the coil+ terminal in both run and start key positions.
Old April 27th, 2018, 04:45 PM
  #35
Ok so now I have installed new points and condenser and coil still won't start. I have battery voltage at the coil. I don't get it it should start grrrr.
Old April 27th, 2018, 05:01 PM
  #36
Use a jumper wire from the positive battery lug connected to the positive side of the coil and the old black wire connected from the negative side of the coil to the points. You need to adjust the point gap .016 on high point of the distributor cam or a 30* dwell.
Note once the engine starts in order to turn it off remove the jumper wire.
Old April 27th, 2018, 05:13 PM
  #37
Used jumper wire still no start.
Old April 27th, 2018, 06:41 PM
  #38
Has the distributor been removed at any time for this project? Did you gap the points? Have you checked for spark?
Old April 27th, 2018, 08:22 PM
  #39
Yes distributor was removed but was reinstalled and timed to 10 degrees. For some reason I have lost power on the distributor neg side of coil. And yes checked spark no spark.
Old April 28th, 2018, 04:43 AM
  #40
There is voltage on the negative side of the coil only when the point are open when the engine is turning. When the points close there is no voltage as it completes the circuit providing ground to the coil. Sounds to me that the points are not opening. Once you get the point gap correct, advance the distributor a little more to get the engine to fire. Once running set your dwell and timing.
Quick Reply: Ignition problems
