1955 olds temperature gage
Not sure if this is the place but i thought i would ask. I have a 1955 olds 88 that i just put in a new temp sending unit and my gage is pegging hot. Is there a way to trouble shoot to figure out whats not working (gage, sender or wired wrong).
Thanks in advance, mike
I went out and turned the key the gage needle moved to the first mark and stayed put. I started the car and in 5 minutes the needle was pegged and yet the motor was not so hot that the thermostat did not open and you could touch the heads with your hand. When I disconnected the wire the gage went all the way down to the cool side. I'm in the process of trying to get back my original sensor. I sold the motor and trans. The sensor I just put in is a TS 6
The 1955 Olds shop manual shows a procedure on pages 13-37 and 13-38 to test the temperature gauge using a tester for the temperature and fuel gauges. I agree that it is likely the sender at fault, especially if it worked previously. I'd try to get the old sender back and use it.
Gage WORKS !!!
I want to thank you guys for your advise. I was able to get the original sending unit from the original 1955 rocket motor. The water temp gage now works like new.
Again thanks for your help, Mike
