62 dynamic heater motor
Old May 20, 2017 | 08:47 AM
Duneracer's Avatar
1962 dynamic 88 no a/c. When you turn the key to on should the heater motor run or should it run when you start the car you have vacuume ? Thanks Steve
Old May 20, 2017 | 11:02 AM
D. Yaros's Avatar
What do you mean by "heater motor?" If you are referring to the fan, it is controlled by a switch. That switch only feeds current to the fan motor when the key is on.
Old May 20, 2017 | 02:29 PM
Duneracer's Avatar
Hi Dave when you put the key in the ignition and turn to the right does the heater fan motor turn on or is it off . When you start the car does the heater fan motor turn on ? At the heater fan motor there is a switch or pot I don't know what it is called it is controlled be vacuum vacuum actuater with no vacuum no continuity with vacuum I get continuity and the motor runs. Here is the problem prior to me replacing vacuum hose and bad vacuum actuators when I would put the key in the ignition and turn to the right the heater fan motor would run at a very low speed. Now I turn the key to the right no fan when I put vacuum to the actuator I have control at the switch low and high here are some pictures hope this helps. Thanks Steve
Old May 22, 2017 | 12:32 PM
D. Yaros's Avatar
My heater fan is off with the key in ACC or RUN mode unless/until I turn the fan switch to on.
I may be wrong but: My car, a 1962 Dynamic 88,has controls for BOTH the heater and summer ventilation. The two MAY be tied together in terms of the the fan. The ventilation control has LOW/MED/MAX buttons. If any of those are depressed the fan should run, when/even if the heater fan switch is set to off?
67 Cutlass Freak
Nov 27, 2015 03:56 PM
slw0501
Sep 5, 2015 03:36 AM
5998DownUnder
Jun 9, 2014 09:35 AM
ent72olds
Dec 14, 2013 06:48 AM
WEBBISH
Dec 25, 2008 04:59 PM
