rear window power
You've tried both dash switch and lock switch?
Open the gate as a DOOR and close it a few times. There's an interlock switch inside the tailgate to prevent opening it as a TAILGATE with window up. That switch may need "jiggling", for lack of a better word.
Past that the tailgate window operates off a circuit breaker same as the power door windows. I think that CB is toward top left of the fuse block.
The real problem is that the weight of the tailgate causes the hinge bushings to sag, so the tailgate doesn't shut all the way, which prevents that interlock switch from closing, which disables the window. You can pull the inner panel from the tailgate and jumper across that switch to test.
thanks guys,
I think it might be the sag, without looking i know the tailgate drops when i open it, will check that.
just learnt it needs major work to pass inspection... frame repair at the rear, I really want to save her, will be getting a repair quote but is there any value in parting out should it be the end of the road? interior is great, dash good, all
chrome trim is great, glass, bumpers, what is valuable on these cars
thanks guys,
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
f-85
Jan 16, 2012 06:10 AM
