62 starfire windows stopped working
Looking to get a power window wiring diagram for my 62 starfire... the motors were all working fine but seems like they got progressively worse then they all stopped working at the same time. the fuse looks fine so i think it has something to do with the power from the fuse box to the switches.i am looking for a wiring diagram for the windows... anybody have any suggestions on how to troubleshoot or diagnose? any help would be appreciated..
There is a relay mounted behind the driver's side kick panel. It probably went south. You should hear it click when you turn the key to run or accessory. It can be bypassed, making the windows "hot" all the time. Olds was the only division to use this "safety feature" at the time. Other divisions' power windows were hot all the time. Replacement relays can be expensive.
widows
Hello
Their is a cb mount on the engine side on the driver side of the fire wall
controls the seat , windows it a 40 amp controls the relay on the inside
on the driver side kick panel
