Parking light connection for accessory lights
Old March 22nd, 2017, 02:06 PM
deejai35's Avatar
Hello,
I am looking to upgrade my headlights on my 72 Cutlass S with projectors from Dapper Lighting. I realize that these modifications aren't for everyone, but I love restomods. Any how, I am trying to find the best way to connect the halos so that they are lit with the parking lights. I have an assembly manual but I want to make sure they don't flash or anything like that. They are a two wire design. Thanks in advance.
deejai35 is offline
Old March 22nd, 2017, 02:36 PM
You can use a relay triggered by the parking lamp (not directionals) feed running the Halo's of the battery.
oldcutlass is online now
Old March 22nd, 2017, 05:34 PM
deejai35's Avatar
Thank you for your reply. I am not the best with wiring, but it sounds like the relay would have the following connections similar to the example below.
30 from fused battery feed
85 ground
86 from parking light switch
87 to the red wire of halos
deejai35 is offline
Old March 22nd, 2017, 06:52 PM
That's correct.
Send us a picture of what it looks like when you're done!
MDchanic is offline
Old March 22nd, 2017, 07:07 PM
Make sure your load (lights) don't exceed the rated load capacity of the relay.
Old March 23rd, 2017, 04:26 AM
deejai35's Avatar
Thanks again for the responses. I am making a few changes to improve the looks of the front end. After I replace the stone shield, grills, and headlights, I will definitely post some new pictures.
deejai35 is offline
BeenThere
September 19th, 2015 07:11 AM
Koda
July 14th, 2014 09:09 PM
Chris J
May 12th, 2013 06:40 PM
cbogartjr
August 3rd, 2008 06:18 AM
Chumley
January 6th, 2007 04:12 PM
Quick Reply: Parking light connection for accessory lights
