H4 Conversion...No plug and play!
Old Aug 7, 2016 | 07:10 AM
Cpriester123's Avatar
I purchased these to replace my halogen sealed beams... As advertised they say just plug and play but when I received them there was NOWHERE on the back of these lights to plug in the original plugs that are currently plugged into my sealed beams. Does anyone know where I can actually purchase some HID, LED, or H4-H1's that actually have the 3 prongs out the back to plug in??? Thanks guys in advance
P.S. I read forum after forum and thread after thread last night for an hour and couldn't find any that helped with my question. And to add, I already have the conversion kit to prevent shortages for the use of high wattages.
Old Aug 7, 2016 | 07:12 AM
svnt442's Avatar
Are there bulbs with the kit?
Old Aug 7, 2016 | 07:15 AM
I ordered low beams and high beams, the highs came with bulbs already inserted but on the back is nowhere to plug anything. And the lows just have two wires out the back, red and black. I'll take a pic real quick and post
Old Aug 7, 2016 | 07:20 AM
Lows. Nowhere to plug in as advertised
Old Aug 7, 2016 | 07:32 AM
Are you sure those are the low beams? The low beams should have three wires.
If those are the low beams then they sent you the wrong units.
If those are the high beams, then just solder two ¼" spade terminals onto them and plug them in.
Those units are supposed to look like this:
Old Aug 7, 2016 | 07:38 AM
I stand corrected, the pic above I posted is the H1 High Beam that replaces H5001 sealed beams.
Old Aug 7, 2016 | 07:42 AM
Yeah I was wrong, they were High Beams that replace H5001 sealed beams. But a question Eric...All 4 of my headlights in the car now, are they all 4 H5001's or H5006's? Are should my car get 2 of each because now I'm a lil confused
Old Aug 7, 2016 | 07:45 AM
Now I feel like a dummy, the H4s do have a 3 prong terminal. Just pull the cap off SMH lol
Old Aug 7, 2016 | 08:10 AM
Originally Posted by Cpriester123
... All 4 of my headlights in the car now, are they all 4 H5001's or H5006's? Are should my car get 2 of each because now I'm a lil confused
You should have two highbeam-only bulbs, in the inner positions, with two wires each, and two low/high bulbs, in the outer positions, with three wires each.
The bulbs have mounting bumps on the back that will only allow them to fit into the correct cups, and only in the correct upside-right position.
Old Aug 7, 2016 | 08:22 AM
Gotcha, appreciate the help Eric. You always lend a hand when possible!
Old Aug 7, 2016 | 10:30 AM
69OldZman's Avatar
Please post some photos when you're done. I have a 69 also and would like to see how that came out.
Old Aug 7, 2016 | 11:14 AM
bccan's Avatar
IIRC the H4 high & low terminal positions are different from your old sealed beams. Positions as I remember them, may want to double check it.
Bulb as viewed from terminal end---------High........Ground
------------------------------------------------------Low
You will likely need to do some clearancing behind the lenses for the rubber boots to allow proper seating & adjustability.
Relays & upgraded wiring recommended especially if using higher wattage bulbs. You can probably get a pre made conversion harness w/ relays. It is not a difficult project & there is no damage to original harness necessary.
Old Aug 8, 2016 | 07:10 PM
car_designer's Avatar
I second what bccan posted. I converted the low beams on my Delta 88 and had to move the terminals around inside the plugs.
ds00469
Jan 25, 2014 05:12 PM
oldcutlass
Sep 1, 2012 06:47 AM
geckonz08
Mar 17, 2010 04:50 PM
Jamesbo
Oct 13, 2009 05:22 AM
Jamesbo
Feb 10, 2009 04:21 PM
