Many diferent elec systems inop.
Just bought a 93 Cutlass Conv. I'll admit I should have checked all the systems before the purchase, but didn't. Now I find missing fuses because they blow due to, I'm sure, shorts in the wiring. I plan to try to run down the shorts but before I do I was hoping for some advice. The systems effected are in the fuse box behind the glove box. Fuses #3 courtesy, #6 Stop, #10 Rear Defog and Cruise and #15 ABS. The wiring diagram shows no common connection with these different systems. If anyone has had similar problems I could use your input.
auto_editor
Vista Cruiser & Wagons
Apr 10, 2011 09:21 AM
